deny specific prefixes in bgp
  • Question
  • Updated 12 months ago
  • Answered
i am trying to deny exact prefixes 66.133.0.0/23 and 66.133.2.0/23 from being advertised and allow everyhting else  to an iBGP neighbor (214.63.21.4) the configuration should be done on 214.63.21.3. using a neighbor route-policy command.
Neighbor 214.63.21.3 is connected to neighbor 214.63.21.4.
can someone help .
thank you,
elie
Photo of Elie Raad
Elie Raad
  • 252 Points 250 badge 2x thumb
Posted 12 months ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Elie,
You should be able to do this with a routing policy. See the link below for syntax details:
http://documentation.extremenetworks.com/exos_22.2/EXOS_21_1/Routing_Policies/r_routing-policy-file-...
For example, you could do:
entry ip_entry {
	if match any {
		nlri  66.133.0.0/23 exact;
		nlri  66.133.0.2/23 exact;
	} then {
		deny;
(Edited)
Hi Elie,
There is an implicit deny on routing policies, so you would need an explicit permit all entry to allow other prefixes.
Photo of Elie Raad
Elie Raad
so the End Result for only denying the 66 and allow all others  would be something like this :
configure bgp neighbor 30.119.210.6 route-policy out AS1187_OUT
edit policy AS1187_OUT
entry TOEXP{
if match {
nlri 66.133.2.0/23 exact;
}then{
deny;
entry TOEXP1 {
if match any {
nlri 0.0.0.0/0;
}then{
permit;
Please, correct me if I am wrong .
thank you very much for your help
That's correct. Just make sure to use 'if match any' for the entries with multiple of the same match conditions.
Photo of Elie Raad
Elie Raad
Thank You Brandon .
Photo of Elie Raad
Elie Raad
Hi Brandon,  i advertised these 2 prefixes 66.133.0.0/23 66.133.2.0/23  on the primary router connected to the primary ISP . i used the policy written above to block these 2 routes from being advertised to the standby router that i connected to the secondary ISP . the router said . Error:  Failed to read policy file AS1187_OUT
can you please advice ?
thank you,
elie
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
First you create policy
edit policy bgp-out
An editor based on vi will be opened (press i to edit, ESC to stop editing, then type :wq to exit
Enter following
entry bgp-out-00 {if match any {
        nlri 66.133.0.0/23;
        nlri 66.133.2.0/23;        }
then {
        deny ;
Then you apply the policy to a neighbor:
configure bgp neighbor 214.63.21.4 route-policy out bgp-out
if you ever after edit the policy, you may refresh changes issuing the command
refresh policy bgp-out
Photo of Elie Raad
Elie Raad
Thank You Nick
Photo of Elie Raad
Elie Raad
Thank You Nick!
why didnt you use the exact keyword after the nlri 66.133.0.0/23 ?
Photo of Elie Raad
Elie Raad
hi Nick,
can you please explain to me what this route-policy do when applied to a bgp neighbor out
entry TOEXP{
if match all {
}then{
deny;
entry TOEXP1{
if match any{
nlri 0.0.0.0/0;
}then{
. once i applied this config on the primary bgp router out toward the standby router the Switch reboots with EPM application wdg timer warning messages and the rtmgr process memory went high
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
Elie,
what EXOS you have on those switches ?
Maybe you are facing: https://gtacknowledge.extremenetworks.com/articles/Solution/Switch-reboots-with-EPM-application-wdg-...
Jarek
Nick Yakimenko
Elie,
I supuse you forgot
then{
permit;
Photo of Elie Raad
Elie Raad
thank you Nick you are right
Photo of Elie Raad
Elie Raad
Jared, that is what i found too . i need to upgrade the OS
