Design High Availability with two switch core Summit 460-24P
  • Question
  • Updated 2 years ago
  • Answered
Hello and good morning
I have a doubt about a design for an small network, consist in two stack one for data and one for voice, those stack are connect it to a switch core, so i want to put another switch core for redundancy and high availability, so i want to know if my design its the correct, can you help me because in my bloody job there is no one to talk about it.
1.- Connect the second switch core to the switch core in production with a etherchannel with 2 ports attached (¿L2 or L3 etherchannel?)
2.-a tier 2 topology will be create it, so from the data stack(3 switch) i connect it to the 2 switch core in in a form of "v shape" or triangule? so 2 ports for each switch to connect to the core?
3.-the same with de voice stack(2 switch) 2 ports for each switch to the core switch,
Can you validate that design please!!!
because i'm 24 and this is my first designing network, so i guess i'm very nervous
Thanks for your time
Best regards!
Photo of Sebastian Rojas
Sebastian Rojas
  • 346 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Sebastian,
The physical network design would be the following based on your description:
I believe that's a good option. However, to accomplish that you have to decide among couple logical options using protocols like MLAG/VRRP/EAPS/ERPS, etc.
Photo of Nicolas Dreher
Nicolas Dreher
  • 90 Points 75 badge 2x thumb
Hi Sebastian,
I agree with Henrique : the dual attachement design is simple and effective.
I would add the simplest solution would be to stack your core switches so they are seen as a single device. You can do this using either stack modules (SummitStack, SummitStack-V80 - in slot B only ! - or SummitStackV over 10Gb uplinks).
The advantage over a simple etherchannel/LACP aggregation (L2 protocols) is that you'd have only one config for both core switches, which means :
- you can aggregate links between the core and acces stacks (using MLAG/LACP)
- you have only one config for both core switches
- you don't need to worry about L3 redundancy (no VRRP)
Anyway, it will be the easy way, compared to a triangle architecture (loop prevention with SpanningTree or EAPS, routing redundancy with VRRP...)
Sebastian Rojas
Hello Henrique,
Thanks for all your help, but in the MLAG from the switch that are connect with LAG, can i do LAG from an example the Data Stack to the core2 ?
or the MLAG feature is asymmetrical from a point of view, does MLAG required that boths ends have to be in stack?
or just one side?
Photo of Henrique
Henrique, Employee
Hi Sebastian,
MLAG will be created between the 2 Core switches. The links between them (with LAG enabled) will be ISC link used to sync fdb table entries.
Regarding the stacks you just need to enable sharing (LAG) for the 2 ports connecting both Core switches.
The vlans from stacked switches must be added to the Core ISC link as well as its MLAG ports (the ports in the Core that connects the stack).
Sebastian Rojas
Hello Henrique
thanks for your help Enrique, i'm going to do it, but it give me a doubt, because i'm going to connect it in triangule shape, looking the vlans configuration that are going to pass, which are the Data and Voice,
the vlan configuration says that is not running STPD, and i learned networking from other vendor, but that a vlan i not running in a STPD instance is not good,
 Admin State:    Enabled         Tagging:        802.1Q Tag 6
        Virtual router: VR-Default
        IPv4 Forwarding: Disabled
        Primary IP    : 130.0.10.19/24
        IPv6 Forwarding: Disabled
        IPv6:           None
        STPD:           None
Looking in the Forum, i supposed, that when a create a vlan i have to create an STPD instance?
configure stpd s0 mode dot1w
conf stpd "s0" add vlan "Default" ports all
conf stpd "s0" add vlan "Voice" ports all
Because in other post it show this
with this configuration the switches assumes that all the ports assigned to vlans are in the STP instance?
Photo of Tony Thornton
Tony Thornton, Extreme Alumnus
  • 1,412 Points 1k badge 2x thumb
Hi Sebastian,
If you are using MLAG on the core switches to connect to the voice and data stacks, this will prevent loops when it's enabled and therefore STP is not needed.  You do not need to enable STP when you create VLANs on EXOS switches.
Hope this helps.
Tony
Sebastian Rojas
Hi Tone,
Right now the data stack are connect to one core only because i have no stack connection between them, because right know i don't have the modules and i don't know when arrives,
So my doubt is this, in the switch core2   i have lag connection with the data stack, so what happens when i connect the data stack to core1
Both core1 and core2 are connect between them with a LAG, so if a create another LAG between data stack and Core1, doesn't create loop?
because i learned with cisco, so thats my doubt, because i thinks it's going to make a loop
data stack --> core 2 --> core2 to core1 --> redundant connection between Core1 and the data Stack?
Does extreme have something enable for blocking redundant ports? because the Data vlan show that has not STP
Hi Sebastian,
You can implement MLAG with the 2 core switches as MLAG peers and the data stack connected to both peers.  There will be a physical loop, but MLAG will block packets going across the ISC link to prevent a logical loop.  Below is some information and a configuration example that may help.
 How to configure MLAG in Extreme switches
Hope this helps.
Regards
Tony
