Device down alarm delay
Justsomebodi
New Contributor III
Hi all
Is there any way of delaying a device down alarm. I was thinking of tweeking the SNMP polling interval, but don't know if this will affect any other alarms.
Thanks
6 REPLIES 6
Jared_Harvey
I had an issue with false positives as well. Within Extreme Management Center web portal, navigate to Administration > Options > SNMP and turn the SNMP retries and timeouts up to decrease the rate of false positives. Be aware, however, that increasing this increases the time it takes to be notified of a positive result for a device that is actually down.
Edith_Mora
Hi
in Administration/Options/Alarms/ Consolidate Email are in 10 minutes default.....
StephanH
Valued Contributor III
Hello all,
I am searching for the same posibility, too.
Any news?
Best Regards
Stephan
Regards Stephan
Justsomebodi
New Contributor III
I am trying to get Netsight to wait 10 minutes to ensure a device is down before it generates alarms.
