Device not reported in NetSight (7.0.6.27) alarm
  • Problem
  • Updated 10 months ago
  • Solved
As you can see below the notification email is not including a device name which really eliminates a lot of the benefit to getting the notification. I was able to find the trap comming in and the source is reported.
Is the problem that the trap is coming from a different IP than the one used to discover the device?
If that is the problem how do I make the trap come from the devices Network Mgmt address. Please don't confuse this with a Mgmt address which i know is on a separate VR. This stack is the building router so it has multipule IPs the one being reported in the trap is the OSPF point to point VLAN.
Thanks,
-----Alarm Message-----
Sent: 10/10/2017 05:18:56 PM
Subject: NetSight Error Alarm: Stack Member Status change
Device:
Severity: Error
Message: Extreme Stack Member Status Changed, Slot ID 6 Slot Operational Status down(2)
Sent: 10/10/2017 05:19:11 PM
Subject: NetSight Error Alarm: Fan Failure
Device:
Severity: Error
Message: Fan Failure at (363226100) 42 days, 0:57:41.00 ExtremeXOS (Stack) version 21.1.3.7 21.1.3.7-patch1-4 by release-manager on Thu Mar 30 08:59:03 EDT 2017 fan number 601
Device:
Severity: Error
Message: Fan Failure at (363226100) 42 days, 0:57:41.00 ExtremeXOS (Stack) version 21.1.3.7 21.1.3.7-patch1-4 by release-manager on Thu Mar 30 08:59:03 EDT 2017 fan number 602
Photo of David Coglianese
David Coglianese, Embassador
  • 6,284 Points 5k badge 2x thumb
Posted 10 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,486 Points 20k badge 2x thumb
Change the overwrite settings in the alarm action.
That is what I use as my default information text - I think the nickname is what you are looking for....
Device: $deviceIp
Severity: $severity
Source: $alarmSource
Alarmsource: $alarmSourceName
NickName: $deviceNickName
DateTime: $time
Message: $message
Cheers,
Ron
Thanks Ronald,
I made the change and will confirm its success the next time I get an email.
