DFE Reboots after 497 Days of Uptime, with f/w prior to 5.12.02
  • Article
  • Updated 4 years ago
  • (Edited)
Article ID: 5719
Products
DFE
Firmware 5.11.29 and lower
Firmware 5.01.67 and lower
Changes
497 days uptime
Symptoms
Reboot
Error message
"pTimerTask previous stamp current stamp"
Cause
DFE firmware prior to version 5.12.02 (5.11.29 and lower) has an issue that prevents individual blades from operating for more than 497 days. This is due to processing of the 32-bit sysuptime counter, which wraps after 497 days.
The Fault Log (5101) of a unit experiencing this issue will contain one or more messages similar to:
  2006-01-04,21:43:28.00   Syslog Message                  04.05.07
      <1>PTimer[4.tGvrpTic]pTimerTask previous stamp.-18  >  current stamp.2
These messages are all part of one reset event. The key wording of interest is "pTimerTask previous stamp". The task (tGvrpTic in this case) and stamp values will vary.
DFE firmware prior to version 5.11.21 (5.01.67 and lower) may experience additional issues after a blade resets due to the counter wrap, leading to further resets of the same type, and requiring the entire system to be user-reset to restore proper operation of the system.
Solution
Upgrade to firmware 5.12.02 or higher.
Pre-upgrade workaround:
Systems approaching 497 days of uptime may be preemptively reset using the 'reset system' CLI command.
See also: 10911.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
