DFE Upgrade Fails with 'Write error occurred!' error
  • Article
  • Updated 5 years ago
Article ID: 5631
Products
DFE
Changes
Firmware upgrade attempt
Symptoms
Cannot copy new firmware file to DFE system
"Error: Write error occurred!"
Cause
There is insufficient room in Flash to store the new image.
With the earliest firmware releases, up to four images could be stored at one time. With current image sizes, there is sufficient room for up to two images at a time. This is all dependent on the total storage size of any user configurations also stored on Flash.
Firmware release notes since version 3.11.04, including latest version 5.13.02, contain this item in the 'Known Restrictions and Limitations' section:
"The system should always have enough memory to accommodate two images. Users should not load more than two images in a system. If an image download fails, and more than one image is stored in the file system, remove an image and retry the download. The 'dir' command does not show the available free memory and failure messages aren't specific enough to determine if this is the cause of the failure. This will be corrected in a future release."
Shown below is an example of issue occurrence, and issue resolution:
DFE(su)->copy tftp://10.10.5.130/DFE-P-51121 DFE-P-51121
Copying image to temporary storage for integrity verification.
Copying image to the file system.
DFE(su)->dir
Images:
Filename: DFE-P-42111
Version: 04.21.11
Date: THU MAY 12 14:06:10 2005
CheckSum: 38ad629f86be67ef35612fb65b545289
Compatibility: 7G4202-30, 7G4202-60, 7G4270-09, 7G4270-10, 7G4270-12,
7G4282-41, 7H4202-72, 7H4203-72, 7H4284-49, 7H4382-25,
7H4382-49, 7H4383-49, 7H4385-49, 7K4290-02, 2G4072-52
Filename: DFE-P-50158 (Active) (Boot)
Version: 05.01.58
Date: THU AUG 11 19:24:08 2005
CheckSum: 000d20d281a43ecfbbfe178a92d2307c
7G4280-19, 7G4282-41, 7H4202-72, 7H4203-72, 7H4284-49,
7H4382-25, 7H4382-49, 7H4383-49, 7H4385-49, 7K4290-02,
2G4072-52
Files:
slot1:
slot2:
MAY 11 2005 07:39:20 8182 cnfmib.cfg
AUG 11 2005 05:08:06 8288 n7config_40507_08112005
MAY 18 2005 08:45:32 8203 N7config_2005_05_18
AUG 11 2005 19:07:34 8316 n7config_42111_08112005
AUG 11 2005 19:38:40 8540 n7config_50158_08112005
slot3:
JUL 08 2004 10:22:48 7152 cnfmib.cfg
slot7:
FEB 10 2004 14:46:50 1648 cnfmib.cfg
DFE(su)->delete dfe-p-42111
DFE(su)->dir
Images:
Version: 05.01.58
2G4072-52
Files:
slot1:
slot2:
slot3:
slot7:
Waiting for chassis to distribute image to compatible modules.
Distribution complete.
DFE(su)->dir
Images:
Version: 05.01.58
2G4072-52
Filename: DFE-P-51121
Version: 05.11.21
Date: THU AUG 11 19:44:40 2005
CheckSum: b458ce46ac762160e04c94fe375651f0
Files:
slot1:
slot2:
slot3:
slot7:
DFE(su)->
Solution
As demonstrated above, delete the non-Active firmware image, then try the upgrade again.
It may also be helpful to do some directory house-cleaning if the non-firmware files are numerous and/or extremely large.
For the full upgrade procedure, see 5040.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
