DHCP clients get IP without configuring DHCP relay on switch
  • Question
  • Updated 3 months ago
  • Answered
In our network environment, we are using x620 and x440 and all users getting IP without configuring DHCP relay agent on the switch. how is it possible?????
Photo of Alok Shukla
Alok Shukla
  • 834 Points 500 badge 2x thumb
Posted 3 months ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,202 Points 3k badge 2x thumb
If the user vlan has a L2 connection all the way to the DHCP server, it will work. Bootprelay is only needed if the DHCP server is on a different vlan than the users.
Photo of Jason Parker
Jason Parker, Employee
  • 2,898 Points 2k badge 2x thumb
The only other reason would be that there is a DHCP server on that VLAN that you are not aware of such as a wireless router added incorrectly or someone added a server but as Brad has stated, if the L2 connection to the DHCP server then addresses will be available to the end clients
