DHCP relay issues
  • Problem
  • Updated 2 years ago
  • Not a Problem
  • (Edited)
i have bootp relay enabled and two vlans, DHCP server on VLAN1.
some clients on VLAN2 are getting IPs assigned for the subnet on VLAN
some  clients on VLAN1 are gettings IPs assigned to subnet on VLAN2. dhcp server is 2008. what am i doing wrong?
Photo of Robin Minshall
Robin Minshall
  • 70 Points
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Can you provide the config pertaining to vlan1-2 and bootp?
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,560 Points 5k badge 2x thumb
Robin,  Were you able to figure it out?  I would take a packet capture to make sure the switch is sending the traffic with the right network.  Then i would look at the DHCP server configuration.
