DHCP scope options for Avaya phone
  • Question
  • Updated 2 years ago
  • Answered
Setting up Summit x440 as DHCP server.
Looking for the syntax, or reference material for Avaya options.
This is the string used in MicroSoft or QIP DHCP.
“MCIPADD=#.#.#.#,MCPORT=1719,TFTPSRVR=#.#.#.#,L2Q=1,L2QVLAN=0′′
Photo of Jeffrey Bourgery
Jeffrey Bourgery
  • 122 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Maybe this?
 configure test dhcp-options code 176 string "MCIPADD=10.8.2.5,MCPORT=1719,TFTPSRVR=10.8.2.5,L2Q=1L2QVLAN=0"
Jeffrey Bourgery
Thank you Jeremy.  That will work, I'll ask the client for the IP office IP address.  Second question, which is probably a no or at least not best practices.  I have a client that has given me one vlan, to use for both voice and data.  Let's say 10 devices, all phones, with a pc connected to the back.  So, If I tag all the ports, the phones will receive an IP address and see the tag, place the tag on the phone.  Question would be would the workstations receive an IP address placed on the back of the phone?  I know that if I separate the phone and data connections, I can put the phones on the vlan tagged, the desktop on the vlan untagged and this would work.  Thank you.
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
Hey Jeffrey, If you are going to do multiple VLANS (tagging the Voice VLAN on the required ports) here is the config I use for Avaya on XOS gear
Enable LLDP:
enable lldp ports <port range>
Enable LLDP Media Capabilities:
configure lldp port <port range> advertise vendor-specific med capabilities
Enable ports <port range> to advertise vlan-names:
configure lldp port <port range> advertise vendor-specific dot1 vlan-name vlan <vlan-name>
Configure LLDP transmit interval to 5 seconds on ports <port range>:
configure lldp transmit-interval 5
This will allow for the Phones to dynamically get the tagged VLAN for voice and hand the untagged off to the PC. Hope this also helps you out
(Edited)
Photo of Brian Simpson
Brian Simpson
  • 150 Points 100 badge 2x thumb
Hi Joseph,
After doing all this, do you push any policy or mac auth to the switches? We use a similar setup with native VLAN/tagged voip VLAN, but once we push Port Config Wizard in Policy Manager, it kills the tagged frames.
Any ideas?
-Brian
