DHCP address is not retire
  • Question
  • Updated 5 years ago
Create Date: Nov 7 2013 10:40AM
Hello!
I have problem, halp me please.
There was external DHCP-server.
vlan Default is take IP-address from it (192.68.4.106/24)
DHCP-server was deleted from this network, DHCP client is disable on switch, but IP-address is not retire.
Here some outputs:
sh "Default"
VLAN Interface with name Default created by user
    Admin State:    Enabled     Tagging:    802.1Q Tag 1
    Description:    None
    Virtual router:    VR-Default
    IPv4 Forwarding: Disabled
    Primary IP    : 192.168.4.106/24
    IPv6 Forwarding: Disabled
    IPv6:         None
    STPD:         s0(Enabled,Auto-bind)
    Protocol:     Match all unfiltered protocols
    Loopback:     Disabled
    NetLogin:     Disabled
    QosProfile:     None configured
    Egress Rate Limit Designated Port: None configured
    Flood Rate Limit QosProfile:       None configured
    Ports:     1.       (Number of active ports=0)
           Untag:   2:41b
 # unconfigure "Default" ipaddress
Error: Dhcp/Bootp configured IP address cannot be removed on VLAN Default
#sh dhcp-client state
Client VLAN     Protocol Server          Current State
 Default         None     0.0.0.0
 #sh ipconfig "Default"
Router Interface on VLAN Default is enabled.
inet 192.168.4.106/24   broadcast 192.168.4.255  Mtu 1500
 #disable dhcp vlan Default
WARNING: VLAN "Default" is not configured as a DHCP client
  Thank you!
(from Aleksandr_Palivoda)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
There are no replies.
