Difference between WM3700 & IDENTIFI regarding the AP upgradation
  • Question
  • Updated 3 years ago
  • Answered
In WM3700 controllers , when the controller is upgraded the access points also get automatically upgraded . Is the same applicable / available in Identify wireless controllers..... is there any extra config needs to be done or will it be by default.
Photo of Saiprasad Rao Rapolu
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Official Response
Yes, the access point will upgrade after a reboot to match what's on the controller. There is also an option to manually update the access points but by default the automatic setting is enabled.
For reference... https://gtacknowledge.extremenetworks.com/articles/Q_A/How-is-firmware-downloaded-to-the-IdentiFi-Wireless-Access-Points
-Doug
(Edited)
