Direct SNMP monitoring of Access points (3805i) possible?
  • Question
  • Updated 1 year ago
  • Answered
Hello,
We use Zabbix as our central monitoring system.
Currently we are monitoring our access points by contacting the controller with SNMP. This works fine.
But I am interested if it is possible to access the access points directly through SNMP?
Kind regards,
Frank
Photo of Frank Veen
Frank Veen
  • 492 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Hi Frank
The AP's don't support direct SNMP access.
-Gareth
Photo of Frank Veen
Frank Veen
Hi Gareth
Thanks for the info.
Frank
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,454 Points 5k badge 2x thumb
you can monitor the AP through the controller (via SNMP). Each AP interface (wired, radio, ssid) is presented as interface on the controller. If the radio goes down then port on controller goes down. if you disable ssid then port on controller goes down.
Regards
Z.
(Edited)
