Disable an individual fan within Extreme XOS
  • Question
  • Updated 3 years ago
  • Answered
Does anyone know if it possible to disable a single fan from within the XOS? I have one of eight fans on the x450 whistling like crazy and need to quite the thing down. The switch is located at one of our Fire Stations and is located near the sleeping quarters which is the main reason I need to shut this thing up. All fans currently show as "Operational at 1000 RPMS" but haven't found a way to adjust these speeds.
Kevin,
Photo of Kevin Craig
Kevin Craig
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,174 Points 50k badge 2x thumb
It's not supported to disable a fan.
-Ron
Photo of Drew C.
Drew C., Community Manager
  • 40,240 Points 20k badge 2x thumb
Hi Kevin,
If you've got support or warranty on the switch, you can request an RMA and have it replaced.  There's no software options that will allow you control over the fans.
