Display port numbers discreetly in config and not in ranges
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
My turn to ask a question
I’m mocking up a customer environment in our lab ( as I frequently do ).
Typically the hardware in the lab does not exactly match thecustomer environment thus I have to Change the port numbers  to match lab gear
For example 3:4 might need to be 1
Search and replace might seem like an obvious solution except
I run into a problems were the ports numbers are described as ranges.
configure vlan NTVLAN add ports 3:1-4, 8:21-22, 8:45-46,9:45 tagged
does anyone know a way around this ? this is problem becausea customer may have 100s of vlans on many switches and I’m currently unable toautomate this process. If the config  wasdisplayed  with each port number discreetlyI could search and replace is there anyway to get it to display in this format?
Photo of simon bingham
simon bingham
  • 1,196 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hello Simon,
Unfortunately there is not a way to change the way the configuration shows up. EXOS is going to place any ports in ranges if it can.
simon bingham
its a shame is not an option like when we do a show config detail
I bet it would a tiny software change to disable at software routine that shows the port ranges.
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
I don't know how helpful it will be, but there's a Python script on our GitHub page that effectively does the opposite of this. It converts a non-stacking config into one that uses slot:port notation.
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/Python/non_stacking_config_conv...
It may give you some ideas on how to "undo" that with your own script to output a config section in the way you need them to be displayed.
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
I created for lab purposes just that what you want, take a customers config and change ports to match my switch I am using. It is written in python. I can send it to you, you only need to adjust it if you dont want to use a webserver to run it.
simon bingham
thanks Oscar , I sort of suspected you might have something as you guys must
do this so much.
Photo of Drew C.
I've posted Oscar's script to GitHub. It works a bit differently than others there, in that it requires a webserver to run. It won't run directly on the switch.
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS/Python/convert_port_config
