Displayed Routes in "sh ipr" different than expected based on LSDB
  • Question
  • Updated 3 days ago
Issue:
Why does sh IPR treat destination networks differently even though at first glance they should be treated the same?
Referring to this diagram: Mah-670-1 and Mah-670-2 are routers serving as the gateway between a building and the larger campus network.  Dug-agg-1 and Dug-agg-2 are the aggregation routers that connect them to the OSPF area (0.0.3.2) that they all belong to.
Mah-670-1 has an OSPF P2P link with Dug-agg-1 and with Mah-670-2.
Mah 670-2 has an OSPF P2P link with Dug-agg-2 and with Mah-670-1.
Dug-agg1 and Dug-agg-2 have an OSPF P2P link to each other as well as P2P links to the larger campus network.  All P2P and passive VLANs are in the same VR.
The sh ipr for mah-670-1 shows :
#or  10.112.1.0/24      10.3.11.157     12   UG-D---um--f- CA-P2P-Dagg1 4d:22h:16m:17s
#or  10.112.1.0/24      10.3.11.214     12   UG-D---um--f- ca-p2p-Mah-int 4d:22h:16m:17s
#or  10.113.1.0/24      10.3.11.157     10   UG-D---um--c- CA-P2P-Dagg1 4d:22h:16m:17s
#or  10.114.1.0/24      10.3.11.157     10   UG-D---um--c- CA-P2P-Dagg1 4d:22h:16m:17s
All of these routes are #or
Why then, does the 10.112.1.0/24 show two routes in the routing table (one through the Agg, one through the bld partner)
While the 10.113 and 10.114 show only one route (through the agg)?
Please note that both routes appear in the lsdb summary for each network.
Sh ospf lsdb
10.112.1.0      10.56.1.4       0x800009ed  117  0xcccd
10.112.1.0      10.56.2.4       0x800009ef 1091  0xadeb
10.113.1.0      10.56.1.4       0x800030d0 1437  0x7120
10.113.1.0      10.56.2.4       0x80004add 1571  0x 267
10.114.1.0      10.56.1.4       0x800025ed 1437  0x4c32
10.114.1.0      10.56.2.4       0x800025f4 1571  0x373f
The LSDB tells the router about both paths to each network.
The IPR table chooses to show both paths for 112.1, But only one path for 113.1 and 114.1
Why?
Photo of Timothy Corcoran
Timothy Corcoran
  • 110 Points 100 badge 2x thumb
Posted 1 week ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,458 Points 10k badge 2x thumb
Hi Timothy,
can you show the complete LSAs for the affected networks, please? I cannot even see of what type each LSA is from your info.
Thanks,
Erik
Timothy Corcoran
Erik,
I edited the displays to show the pertinent information for the sake of brevity.  the full output is included below:
Mah-670-1.1 # vir vr-ca
(vr VR-Campus) Mah-670-1.2 # sh ospf lsdb
                AS External LSAs
Link State ID   Adv Router      Seq#         Age Chksum  Tag
0.0.0.0         10.56.240.4     0x80004d64  857  0x39a5   0
10.12.4.0       10.255.230.4    0x80000904 1559  0x1358   0
10.12.7.0       10.255.230.4    0x80000904 1559  0xf176   0
10.12.9.0       10.255.230.4    0x80000904 1559  0xdb8a   0
10.12.10.0      10.255.230.4    0x80000904 1559  0xd094   0
10.12.13.0      10.255.230.4    0x80000904 1559  0xafb2   0
10.12.14.0      10.255.230.4    0x80000904 1559  0xa4bc   0
10.12.55.0      10.255.229.4    0x8000aa93  967  0x705a   0
10.12.55.0      10.255.230.4    0x80000904 1559  0x6d8d   0
10.12.65.0      10.255.230.4    0x800003bf 1109  0x c6c   0
10.27.60.0      10.255.242.4    0x80004e92  990  0x138b   0
10.91.0.0       10.92.241.4     0x80005a19 1057  0x7082   0
10.97.1.0       10.255.241.4    0x80002308 1542  0xa190   0
10.99.9.0       10.255.229.4    0x80002d64 1538  0x9ded   0
129.63.40.0     10.255.242.4    0x8001cf66  990  0x2dba   0
129.63.41.0     10.255.242.4    0x8001cf66  990  0x22c4   0
129.63.42.0     10.255.8.4      0x8000040b  337  0x9b5e   0
129.63.43.0     10.255.8.4      0x8000040b  337  0x9068   0
172.31.146.0    10.11.240.4     0x800078bf 1366  0x1c10   0
172.31.146.0    10.11.241.4     0x800078bf 1389  0x3fe8   0
192.168.1.0     10.255.175.4    0x80007972 1140  0xfedc   0
192.168.125.0   10.255.8.4      0x80013ae1  938  0x8ea1   0
                Router LSAs for area 0.0.3.2
Link State ID   Adv Router      Seq#         Age Chksum  #Links
10.33.240.4     10.33.240.4     0x80000181  512  0xbe7f  8
10.33.241.4     10.33.241.4     0x80000182  519  0x af7  8
10.34.240.4     10.34.240.4     0x8000c4dc 1090  0x89b2  7
10.34.241.4     10.34.241.4     0x8000c4dd 1063  0x640e  6
10.38.240.4     10.38.240.4     0x800069ff 1063  0xbef2 12
10.38.241.4     10.38.241.4     0x80006a37 1385  0xee5f 12
10.44.240.4     10.44.240.4     0x80000339 1565  0x54c7  6
10.44.241.4     10.44.241.4     0x80000339 1603  0x88fd  7
10.56.1.4       10.56.1.4       0x8000dbd0  152  0x13eb 15
10.56.2.4       10.56.2.4       0x8000e3b8  847  0x59d9 13
10.56.220.4     10.56.220.4     0x80003e7b  630  0xa971 12
10.56.221.4     10.56.221.4     0x80003e6e 1330  0xa945 12
10.95.240.4     10.95.240.4     0x8000492e  615  0xeac1  8
10.95.241.4     10.95.241.4     0x8000492c 1659  0xec06  6
10.255.59.4     10.255.59.4     0x8000daeb  529  0x5906 18
10.255.60.4     10.255.60.4     0x8000e412 1271  0xc338 18
                Summary LSAs for area 0.0.3.2
10.3.0.128      10.56.1.4       0x80000f53  753  0x41d8
10.3.0.128      10.56.2.4       0x80000f57  608  0x1ef8
10.3.0.152      10.56.1.4       0x80003163  663  0x3da0
10.3.0.152      10.56.2.4       0x8000316f 1058  0x5a70
10.3.0.176      10.56.1.4       0x80003162  663  0x764c
10.3.0.176      10.56.2.4       0x80008530 1058  0xd6c8
10.3.0.200      10.56.1.4       0x80000f60  513  0xefde
10.3.0.200      10.56.2.4       0x80000f60  399  0xfcce
10.3.0.224      10.56.1.4       0x80003162  663  0xa8e7
10.3.0.224      10.56.2.4       0x8000316d 1058  0x4f3b
10.3.0.248      10.56.1.4       0x80000f5d  213  0x2877
10.3.0.248      10.56.2.4       0x80000f62   69  0x 398
10.3.1.4        10.56.1.4       0x80003161  663  0x1859
10.3.1.4        10.56.2.4       0x8000316d 1058  0xf86b
10.3.1.32       10.56.1.4       0x8000850a  663  0xb0a7
10.3.1.32       10.56.2.4       0x8000852c 1058  0x79b9
10.3.1.56       10.56.1.4       0x80003163  663  0xf547
10.3.1.56       10.56.2.4       0x8000316f 1058  0xfe2d
10.3.1.80       10.56.1.4       0x8000bd7c  663  0x413c
10.3.1.80       10.56.2.4       0x8000bda3 1058  0xff53
10.3.1.104      10.56.1.4       0x80000628 1774  0x2051
10.3.1.104      10.56.2.4       0x8000062a  968  0x2943
10.3.1.132      10.56.1.4       0x80003162  663  0x11de
10.3.1.132      10.56.2.4       0x8000bda1 1058  0xf927
10.3.1.156      10.56.1.4       0x80003162  663  0x34a1
10.3.1.156      10.56.2.4       0x8000316d 1058  0x 3c8
10.3.1.180      10.56.1.4       0x80003163  663  0x417b
10.3.1.180      10.56.2.4       0x8000d99c 1058  0xa538
10.3.1.204      10.56.1.4       0x80003164  784  0x4e55
10.3.1.204      10.56.2.4       0x8000bda0 1058  0x15c6
10.3.1.228      10.56.1.4       0x800004b4 1144  0x4424
10.3.1.228      10.56.2.4       0x800004b5 1508  0x2741
10.3.2.0        10.56.1.4       0x80003163  663  0x452b
10.3.2.0        10.56.2.4       0x8000bd9f 1058  0x c9c
10.3.2.36       10.56.1.4       0x8000d96b  663  0xa9f5
10.3.2.36       10.56.2.4       0x8000bda4 1058  0xc0ba
10.3.2.84       10.56.1.4       0x80003163  663  0x e0c
10.3.2.84       10.56.2.4       0x8000d99c 1058  0x5ede
10.3.2.108      10.56.1.4       0x80003162  663  0x bf9
10.3.2.108      10.56.2.4       0x8000bda4 1058  0xd95b
10.3.2.204      10.56.1.4       0x80003162  663  0x475d
10.3.2.204      10.56.2.4       0x80004b27 1058  0x7c46
10.3.2.228      10.56.1.4       0x80000f5f  513  0xd6d8
10.3.2.228      10.56.2.4       0x80000f65  429  0xc3e4
10.3.3.64       10.56.1.4       0x80003162  663  0xcd60
10.3.3.64       10.56.2.4       0x800058de 1058  0x5831
10.3.3.80       10.56.1.4       0x80000f84 1414  0x4fce
10.3.3.80       10.56.2.4       0x80000f8c 1328  0x38dc
10.3.3.100      10.56.1.4       0x80000f85    3  0x709a
10.3.3.100      10.56.2.4       0x8000852f 1748  0xc621
10.3.3.124      10.56.1.4       0x80003163 1444  0x717f
10.3.3.124      10.56.2.4       0x80000f88 1328  0x727c
10.3.3.148      10.56.1.4       0x80003162  663  0x6e6d
10.3.3.148      10.56.2.4       0x80004b6e 1058  0x159d
10.3.3.176      10.56.1.4       0x80000f61  333  0xd10f
10.3.3.176      10.56.2.4       0x80000f69  189  0xba1d
10.3.3.196      10.56.1.4       0x80000f61 1744  0xf4d9
10.3.3.196      10.56.2.4       0x80000f65 1598  0xf9cd
10.3.3.220      10.56.1.4       0x80000f61  333  0x189c
10.3.3.220      10.56.2.4       0x80000f66  219  0xf2bd
10.3.4.64       10.56.1.4       0x80003162  663  0xae80
10.3.4.64       10.56.2.4       0x8000b715 1058  0xc230
10.3.4.88       10.56.1.4       0x80003162  663  0xd143
10.3.4.88       10.56.2.4       0x8000b748 1058  0x5752
10.3.4.112      10.56.1.4       0x80003162  663  0xe01c
10.3.4.112      10.56.2.4       0x8000b715 1058  0xf4cb
10.3.4.144      10.56.1.4       0x80003162  663  0x8b53
10.3.4.144      10.56.2.4       0x800058dc 1058  0x2e0c
10.3.4.168      10.56.1.4       0x80003162  663  0xae16
10.3.4.168      10.56.2.4       0x800058de 1058  0x25fc
10.3.5.52       10.56.1.4       0x80000f5e    4  0x8ad5
10.3.5.52       10.56.2.4       0x80000f60 1659  0x93c7
10.3.5.80       10.56.1.4       0x80000f60  364  0x81be
10.3.5.80       10.56.2.4       0x80000f65  220  0x5cdf
10.3.5.108      10.56.1.4       0x80000f61    4  0x66bc
10.3.5.108      10.56.2.4       0x80000f61 1659  0x5fc2
10.3.5.136      10.56.1.4       0x8000262a  664  0x62c6
10.3.5.136      10.56.2.4       0x80002632 1059  0x5fbe
10.3.5.164      10.56.1.4       0x80003162  664  0xcbfb
10.3.5.164      10.56.2.4       0x80008351 1059  0xdbab
10.3.5.192      10.56.1.4       0x8000262c  664  0x40ac
10.3.5.192      10.56.2.4       0x80002633 1059  0x2bb9
10.3.5.220      10.56.1.4       0x8000267b  664  0x740f
10.3.5.220      10.56.2.4       0x80002685 1059  0x6d09
10.3.5.248      10.56.1.4       0x8000267c  664  0x6df6
10.3.5.248      10.56.2.4       0x80002686 1059  0x3e1d
10.3.6.20       10.56.1.4       0x8000267f  664  0x4df7
10.3.6.20       10.56.2.4       0x80002686 1059  0x3805
10.3.6.48       10.56.1.4       0x8000011d 1535  0x545e
10.3.6.48       10.56.2.4       0x80000f0d 1149  0x575a
10.3.6.76       10.56.1.4       0x800001be  965  0x ce6
10.3.6.76       10.56.2.4       0x800001be 1749  0xf003
10.3.6.116      10.56.1.4       0x80003162  664  0x8e6a
10.3.6.116      10.56.2.4       0x8000771f 1059  0x4fa3
10.3.6.204      10.56.1.4       0x80003155  664  0x7136
10.3.6.204      10.56.2.4       0x80003162 1059  0x3c5f
10.3.6.208      10.56.1.4       0x80000f54  364  0xc5fe
10.3.6.208      10.56.2.4       0x80000f58  190  0xa21f
10.3.6.244      10.56.1.4       0x80003163  664  0x9bd9
10.3.6.244      10.56.2.4       0x800078d0 1059  0xbb08
10.3.6.248      10.56.1.4       0x80003163  664  0x73fd
10.3.6.248      10.56.2.4       0x800078d9 1059  0x6d4b
10.3.7.68       10.56.1.4       0x80000604   94  0xa30e
10.3.7.68       10.56.2.4       0x80000605 1059  0xaefe
10.3.7.96       10.56.1.4       0x80000604  244  0x9ef4
10.3.7.96       10.56.2.4       0x80000605 1209  0x8112
10.3.7.124      10.56.1.4       0x8000060b   94  0x77f8
10.3.7.124      10.56.2.4       0x8000060d 1179  0x6c01
10.3.8.0        10.56.1.4       0x80003173 1535  0xf661
10.3.8.0        10.56.2.4       0x80005b5c 1749  0x9fa4
10.3.8.40       10.56.1.4       0x80003162  664  0x73cf
10.3.8.40       10.56.2.4       0x80006f3a 1059  0x1614
10.3.8.68       10.56.1.4       0x80003162  664  0x6eb6
10.3.8.68       10.56.2.4       0x80006f65 1059  0x9252
10.3.8.96       10.56.1.4       0x80003162  664  0x55b3
10.3.8.96       10.56.2.4       0x80006f3b 1059  0xe10f
10.3.8.200      10.56.1.4       0x80003162  664  0x415f
10.3.8.200      10.56.2.4       0x80004b62 1059  0xd7af
10.3.9.56       10.56.1.4       0x80000903 1115  0x3b78
10.3.9.56       10.56.2.4       0x80000905 1659  0x1c96
10.3.9.104      10.56.1.4       0x800023e8  664  0x 386
10.3.9.104      10.56.2.4       0x800023f1 1059  0xfd7f
10.3.9.108      10.56.1.4       0x80003162  664  0xd12a
10.3.9.108      10.56.2.4       0x80005a3e 1059  0x8374
10.3.9.124      10.56.1.4       0x8000040c  334  0x5120
 10.3.9.124      10.56.2.4       0x8000040b  400  0x600f
10.3.9.152      10.56.1.4       0x8000040b  334  0x4e06
10.3.9.152      10.56.2.4       0x8000040c  400  0x3123
10.3.9.180      10.56.1.4       0x8000040c  334  0x3304
10.3.9.180      10.56.2.4       0x8000040c  400  0x2c0a
10.3.10.44      10.56.1.4       0x80003162  664  0x49f1
10.3.10.44      10.56.2.4       0x80004a1e 1059  0x6bfb
10.3.10.244     10.56.1.4       0x8000040a  394  0x9564
 10.3.10.244     10.56.2.4       0x8000040b  430  0xa055
10.3.11.16      10.56.1.4       0x8000040b  394  0x8d4d
10.3.11.16      10.56.2.4       0x8000040c  430  0x706a
10.3.11.44      10.56.1.4       0x8000040a  364  0x7649
10.3.11.44      10.56.2.4       0x8000040c  430  0x6b51
10.3.11.72      10.56.1.4       0x80001f72  514  0x27fa
 10.3.11.72      10.56.2.4       0x80001f7a  549  0x24f2
10.3.11.100     10.56.1.4       0x800022a4  785  0xb41a
10.3.11.100     10.56.2.4       0x800022ac 1750  0x893e
10.3.11.128     10.56.1.4       0x80001f73  515  0x 7df
10.3.11.128     10.56.2.4       0x80001f7c 1750  0xedee
10.3.16.0       10.56.1.4       0x80003173 1536  0x86cd
 10.3.16.0       10.56.2.4       0x80005b5c 1750  0x2f11
10.3.16.96      10.56.1.4       0x80003162  665  0xbc4c
10.3.16.96      10.56.2.4       0x80004fbb 1060  0xa8e7
10.3.16.160     10.56.1.4       0x80003166  725  0x823a
10.3.16.160     10.56.2.4       0x80003175  790  0x4965
10.6.0.8        10.56.1.4       0x8000040a  425  0x5d8a
10.6.0.8        10.56.2.4       0x8000040b  461  0x40a7
 10.6.1.0        10.56.1.4       0x8000040a  365  0x8c63
10.6.1.0        10.56.2.4       0x8000040c  431  0x816b
10.6.2.0        10.56.1.4       0x8000040a  365  0x816d
10.6.2.0        10.56.2.4       0x8000040c  431  0x7675
10.6.3.0        10.56.1.4       0x8000040a  365  0x7677
10.6.3.0        10.56.2.4       0x8000040c  431  0x6b7f
10.6.4.0        10.56.1.4       0x8000040a  365  0x6b81
 10.6.4.0        10.56.2.4       0x8000040c  431  0x6089
10.6.5.0        10.56.1.4       0x8000040a  365  0x608b
10.6.5.0        10.56.2.4       0x8000040c  431  0x5593
10.6.6.0        10.56.1.4       0x8000040a  365  0x5595
10.6.6.0        10.56.2.4       0x8000040c  431  0x4a9d
10.6.124.0      10.56.1.4       0x8000040a  365  0x393c
10.6.124.0      10.56.2.4       0x8000040b  431  0x442d
 10.7.0.8        10.56.1.4       0x80003162  665  0x2d32
10.7.0.8        10.56.2.4       0x8000316f 1060  0xf75b
10.7.3.0        10.56.1.4       0x8000040a  185  0xba2a
10.7.3.0        10.56.2.4       0x8000040b  221  0x9d47
10.7.124.0      10.56.1.4       0x80003162  665  0x45a1
10.7.124.0      10.56.2.4       0x8000316f 1060  0x10ca
10.10.60.0      10.56.1.4       0x8000017e 1776  0x1922
 10.10.60.0      10.56.2.4       0x8000017f  670  0xfb3f
10.10.124.0     10.56.1.4       0x8000017f  125  0x4fab
10.10.124.0     10.56.2.4       0x8000017f  820  0x34c7
10.11.129.0     10.56.1.4       0x80003163  665  0xa43d
10.11.129.0     10.56.2.4       0x800078d1 1060  0xae82
10.12.0.0       10.56.1.4       0x80000a46  575  0xc6e2
10.12.0.0       10.56.2.4       0x80000a48 1690  0xa701
 10.12.0.4       10.56.1.4       0x80000905    5  0x38ad
10.12.0.4       10.56.2.4       0x80000907  550  0x19cb
10.12.1.0       10.56.1.4       0x80003166  725  0x2c30
10.12.1.0       10.56.2.4       0x80003175  790  0xf25b
10.12.2.0       10.56.1.4       0x80000906  725  0x6e73
10.12.2.0       10.56.2.4       0x80000907  790  0x5190
10.12.3.0       10.56.1.4       0x80003166  725  0x1644
10.12.3.0       10.56.2.4       0x80003175  790  0xdc6f
10.12.5.0       10.56.1.4       0x80003166  725  0xff58
 10.12.5.0       10.56.2.4       0x80003175  790  0xc683
10.12.6.0       10.56.1.4       0x80003166  725  0xf462
10.12.6.0       10.56.2.4       0x80003175  790  0xbb8d
10.12.8.0       10.56.1.4       0x80003166  725  0xde76
10.12.8.0       10.56.2.4       0x80003175  790  0xa5a1
10.12.25.0      10.56.1.4       0x80000906  725  0x5c70
 10.12.25.0      10.56.2.4       0x80000907  790  0x3f8d
10.12.40.0      10.56.1.4       0x80003166  725  0x7db7
10.12.40.0      10.56.2.4       0x80003175  790  0x44e2
10.12.41.0      10.56.1.4       0x80003166  725  0x72c1
10.12.41.0      10.56.2.4       0x80003175  790  0x39ec
10.12.44.0      10.56.1.4       0x80003166  725  0x51df
 10.12.44.0      10.56.2.4       0x80003175  790  0x180b
10.12.45.0      10.56.1.4       0x80003166  725  0x46e9
10.12.45.0      10.56.2.4       0x80003175  790  0x d15
10.20.0.0       10.56.1.4       0x80003162  665  0xe079
10.20.0.0       10.56.2.4       0x80003171 1060  0xa7a4
10.20.1.0       10.56.1.4       0x80003162  665  0xabb0
10.20.1.0       10.56.2.4       0x800076e3 1060  0xd1c2
 10.20.2.0       10.56.1.4       0x80003162  665  0xa0ba
10.20.2.0       10.56.2.4       0x800076e3 1060  0xc6cc
10.20.3.0       10.56.1.4       0x80003162  665  0x95c4
10.20.3.0       10.56.2.4       0x800076e3 1060  0xbbd6
10.20.4.0       10.56.1.4       0x80003162  665  0x8ace
10.20.4.0       10.56.2.4       0x800076e3 1060  0xb0e0
10.20.124.0     10.56.1.4       0x80003162  665  0x5889
 10.20.124.0     10.56.2.4       0x80006f65 1060  0x900f
10.21.0.0       10.56.1.4       0x80000458   95  0x484c
10.21.0.0       10.56.2.4       0x80000457  281  0x2f67
10.21.1.0       10.56.1.4       0x80000456   97  0x6729
10.21.1.0       10.56.2.4       0x80000457  281  0x4a46
10.21.60.0      10.56.1.4       0x80000456   97  0xdb79
10.21.60.0      10.56.2.4       0x80000457  281  0xbe96
 10.21.124.0     10.56.1.4       0x80000456   97  0x1402
10.21.124.0     10.56.2.4       0x80000457  281  0xf61f
10.22.1.0       10.56.1.4       0x80003162  665  0x7fdc
10.22.1.0       10.56.2.4       0x80005bbd 1060  0x577c
10.25.0.0       10.56.1.4       0x80000458   95  0x1878
10.25.0.0       10.56.2.4       0x80000457  281  0xfe93
10.25.1.0       10.56.1.4       0x800003be 1146  0x69bb
 10.25.1.0       10.56.2.4       0x800003bf 1060  0x4cd8
10.25.2.0       10.56.1.4       0x80000456   65  0x4049
10.25.2.0       10.56.2.4       0x80000457  281  0x2366
10.25.3.0       10.56.1.4       0x800003be 1506  0x53cf
10.25.3.0       10.56.2.4       0x800003bf 1420  0x36ec
10.25.124.0     10.56.1.4       0x800003be 1506  0x1694
10.25.124.0     10.56.2.4       0x800003bf 1420  0xf8b1
 10.27.0.0       10.56.1.4       0x80000456   95  0x 48c
10.27.0.0       10.56.2.4       0x80000457  281  0xe6a9
10.27.60.0      10.56.1.4       0x80000456   35  0x93bb
10.27.60.0      10.56.2.4       0x80000457  221  0x76d8
10.36.1.0       10.56.1.4       0x80003162  665  0xea61
10.36.1.0       10.56.2.4       0x8000bd9f 1060  0xafd3
10.38.8.0       10.56.1.4       0x80000692  155  0xa697
 10.38.8.0       10.56.2.4       0x80000692 1510  0x9f9d
10.39.1.0       10.56.1.4       0x80000f54   65  0x99d7
10.39.1.0       10.56.2.4       0x80000f57 1690  0x78f6
10.39.2.0       10.56.1.4       0x80000f54   65  0x8ee1
10.39.2.0       10.56.2.4       0x80000f57 1690  0x6d01
10.39.124.0     10.56.1.4       0x80000f54   65  0x46b0
10.39.124.0     10.56.2.4       0x80000f57 1690  0x25cf
 10.46.1.0       10.56.1.4       0x80003163  515  0x70d0
10.46.1.0       10.56.2.4       0x8000bdae   41  0x2d3b
10.46.2.0       10.56.1.4       0x80003163  515  0x65da
10.46.2.0       10.56.2.4       0x8000bdae   41  0x2245
10.46.3.0       10.56.1.4       0x80003163  515  0x5ae4
10.46.3.0       10.56.2.4       0x8000bdae   41  0x174f
10.46.4.0       10.56.1.4       0x80000e66  756  0xc695
 10.46.4.0       10.56.2.4       0x80000e6a  161  0xa3b5
10.46.5.0       10.56.1.4       0x80000e66  756  0xbb9f
10.46.5.0       10.56.2.4       0x80000e6a  161  0x98bf
10.51.1.0       10.56.1.4       0x80003162  665  0x4af0
10.51.1.0       10.56.2.4       0x80004b28 1060  0x7dda
10.51.124.0     10.56.1.4       0x800013af  335  0xb6da
10.51.124.0     10.56.2.4       0x800013b4  401  0xb9cf
 10.52.0.0       10.56.1.4       0x8000040a  425  0x833e
10.52.0.0       10.56.2.4       0x8000040b  461  0x665b
10.53.1.0       10.56.1.4       0x80000456   35  0x e5e
10.53.1.0       10.56.2.4       0x80000457  221  0xf07b
10.54.1.0       10.56.1.4       0x800022a4  515  0xba4c
10.54.1.0       10.56.2.4       0x800022ad 1750  0xa15b
10.54.2.0       10.56.1.4       0x800022a4  515  0xaf56
 10.54.2.0       10.56.2.4       0x800022ad 1750  0x9665
10.54.3.0       10.56.1.4       0x800022a4  515  0xa460
10.54.3.0       10.56.2.4       0x800022ad 1750  0x8b6f
10.54.25.0      10.56.1.4       0x800022a4  515  0xb13d
10.54.25.0      10.56.2.4       0x800022ad 1750  0x984c
10.54.124.0     10.56.1.4       0x800022a4  515  0x6725
10.54.124.0     10.56.2.4       0x800022ad 1750  0x4e34
 10.55.1.0       10.56.1.4       0x80003162  665  0x 633
10.55.1.0       10.56.2.4       0x8000b715 1060  0x1ae2
10.55.2.0       10.56.1.4       0x80003162  665  0xfa3d
10.55.2.0       10.56.2.4       0x8000b715 1060  0x fec
10.55.3.0       10.56.1.4       0x80003162  665  0xef47
10.55.3.0       10.56.2.4       0x8000b715 1060  0x 4f6
10.55.124.0     10.56.1.4       0x80003162  665  0xb20c
 10.55.124.0     10.56.2.4       0x800065e2 1060  0x22e4
10.56.56.0      10.56.1.4       0x80003162  665  0x9a66
10.56.56.0      10.56.2.4       0x8000bd9f 1060  0x5fd8
10.58.1.0       10.56.1.4       0x80000456   95  0xa9c1
10.58.1.0       10.56.2.4       0x80000457  281  0x8cde
10.59.0.0       10.56.1.4       0x80000456   95  0x96d7
 10.59.0.0       10.56.2.4       0x80000457  281  0x79f4
10.61.1.0       10.56.1.4       0x80003166    5  0xb579
10.61.1.0       10.56.2.4       0x8000bda7 1330  0x86d9
10.62.1.0       10.56.1.4       0x80000609   97  0xe5d0
10.62.1.0       10.56.2.4       0x8000060b 1180  0xdad8
10.62.124.0     10.56.1.4       0x80000609   95  0x92a9
10.62.124.0     10.56.2.4       0x8000060b 1210  0x87b1
 10.63.1.0       10.56.1.4       0x80003162  665  0xa58b
10.63.1.0       10.56.2.4       0x800058df 1060  0x2e5d
10.64.1.0       10.56.1.4       0x80003162  665  0x9996
10.64.1.0       10.56.2.4       0x800058df 1060  0x2268
10.65.1.0       10.56.1.4       0x80003162  665  0x8da1
10.65.1.0       10.56.2.4       0x800058de 1060  0x1872
10.65.2.0       10.56.1.4       0x80003162  665  0x82ab
 10.65.2.0       10.56.2.4       0x800058df 1060  0x b7d
10.65.3.0       10.56.1.4       0x80003162  665  0x77b5
10.65.3.0       10.56.2.4       0x800058de 1060  0x 286
10.65.4.0       10.56.1.4       0x80003162  665  0x6cbf
10.65.4.0       10.56.2.4       0x800058df 1060  0xf491
10.65.5.0       10.56.1.4       0x80003162  665  0x61c9
10.65.5.0       10.56.2.4       0x800058df 1060  0xe99b
10.65.6.0       10.56.1.4       0x80003162  665  0x56d3
 10.65.6.0       10.56.2.4       0x8000399c 1060  0xc224
10.65.124.0     10.56.1.4       0x80003162  665  0x3a7a
10.65.124.0     10.56.2.4       0x8000399b 1060  0xa8c9
10.99.0.0       10.56.1.4       0x80003162  665  0x15f7
10.99.0.0       10.56.2.4       0x80003171 1060  0xdb23
10.99.1.0       10.56.1.4       0x80003162  665  0x30d6
10.99.1.0       10.56.2.4       0x80003171 1060  0xf602
 10.99.2.0       10.56.1.4       0x80003162  665  0x25e0
10.99.2.0       10.56.2.4       0x80003171 1060  0xeb0c
10.99.3.0       10.56.1.4       0x80003162  665  0x1aea
10.99.3.0       10.56.2.4       0x80003171 1060  0xe016
10.99.4.0       10.56.1.4       0x80003162  665  0x ff4
10.99.4.0       10.56.2.4       0x80003171 1060  0xd520
 10.99.5.0       10.56.1.4       0x80003162  665  0x 4fe
10.99.5.0       10.56.2.4       0x80003171 1060  0xca2a
10.99.25.0      10.56.1.4       0x800015b2 1776  0xdadf
10.99.25.0      10.56.2.4       0x800015b8  940  0xb302
10.99.60.0      10.56.1.4       0x80003162  665  0xa427
10.99.60.0      10.56.2.4       0x80003171 1060  0x6b52
10.99.124.0     10.56.1.4       0x80003162  665  0xdcaf
10.99.124.0     10.56.2.4       0x80003171 1060  0xa3da
10.103.1.0      10.56.1.4       0x8000316e 1746  0xab51
10.103.1.0      10.56.2.4       0x8000bdad 1600  0x9499
10.112.1.0      10.56.1.4       0x80000a7e 1146  0xa860
10.112.1.0      10.56.2.4       0x80000a81  580  0x877f
10.113.1.0      10.56.1.4       0x80003162  665  0x4bb3
10.113.1.0      10.56.2.4       0x80004b6f 1060  0xdbfa
10.114.1.0      10.56.1.4       0x8000267f  665  0x26c5
10.114.1.0      10.56.2.4       0x80002686 1060  0x11d2
10.114.2.0      10.56.1.4       0x8000267f  665  0x1bcf
10.114.2.0      10.56.2.4       0x80002686 1060  0x 6dc
10.114.3.0      10.56.1.4       0x8000267f  665  0x10d9
10.114.3.0      10.56.2.4       0x80002686 1060  0xfae6
Thanks, but I need the detailed output for just the LSAs in question. This should be possible to get using the following commands (untested, so you might need to tweak them):
show ospf lsdb detail lsid 10.112.1.0
show ospf lsdb detail lsid 10.113.1.0
I want to check if those are of different type, e.g. one type 3 and the other type 5.
Timothy Corcoran
Understood.  Here we go:
(vr VR-Campus) Mah-670-1.3 # sh ospf lsdb det lsid 10.112.1.0
                LSAs for Area: 0.0.3.2
LSA Type: Summary Network
Link State Id: 10.112.1.0 (Destination Network Ip Address)
Options: None
Advertising Router: 10.56.1.4
Sequence number: 0x80000a81
Checksum: 0xa263
Length: 28
Receive Interface: None
Network Mask: 255.255.255.0
Cost (TOS 0 Metric): 10
Options: None
Advertising Router: 10.56.2.4
Sequence number: 0x80000a83
Checksum: 0x8381
Length: 28
Cost (TOS 0 Metric): 8
(vr VR-Campus) Mah-670-1.4 # sh ospf lsdb det lsid 10.113.1.0
Link State Id: 10.113.1.0 (Destination Network Ip Address)
Options: None
Sequence number: 0x80003164
Checksum: 0x47b5
Length: 28
Options: None
Sequence number: 0x80004b72
Checksum: 0xd5fd
Length: 28
(vr VR-Campus) Mah-670-1.5 #
Timothy Corcoran
This is the nub of my question.  OSPF seems to see 10.112.1.0 and 10.113.1.0 in the same way but show iproute treats them differently.
(vr VR-Campus) Mah-670-1.10 # sh ipr 10.112.1.0/24
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#or  10.112.1.0/24      10.3.11.157     12   UG-D---um--f- CA-P2P-Dagg1 8d:0h:41m:33s
#or  10.112.1.0/24      10.3.11.214     12   UG-D---um--f- ca-p2p-Mah-int 8d:0h:41m:33s
       (mo) MOSPF (o) OSPF, (o1) OSPFExt1, (o2) OSPFExt2,
       (oa) OSPFIntra, (oe) OSPFAsExt, (or) OSPFInter, (pd) PIM-DM, (ps) PIM-SM,
       (r) RIP, (ra) RtAdvrt, (s) Static, (sv) SLB_VIP, (un) UnKnown,
       (*) Preferred unicast route (@) Preferred multicast route,
       (#) Preferred unicast and multicast route.
Flags: (b) BFD protection requested, (B) BlackHole, (c) Compressed, (D) Dynamic,
       (f) Provided to FIB, (G) Gateway, (H) Host Route, (l) Calculated LDP LSP,
       (L) Matching LDP LSP, (m) Multicast, (p) BFD protection active, (P) LPM-routing,
       (R) Modified, (s) Static LSP, (S) Static, (t) Calculated RSVP-TE LSP,
       (T) Matching RSVP-TE LSP, (u) Unicast, (U) Up, (3) L3VPN Route.
MPLS Label: (S) Bottom of Label Stack
Mask distribution:
     2 routes at length 24
Route Origin distribution:
     2 routes from OSPFInter
Total number of routes = 2
Total number of compressed routes = 0
(vr VR-Campus) Mah-670-1.11 # sh ipr 10.113.1.0/24
#or  10.113.1.0/24      10.3.11.157     10   UG-D---um--c- CA-P2P-Dagg1 8d:0h:41m:40s
Mask distribution:
     1 routes at length 24
     1 routes from OSPFInter
Total number of routes = 1
Total number of compressed routes = 1
(vr VR-Campus) Mah-670-1.12 #
my original answer to the question was lost in the platform troubles. :-(
The OSPF LSDB show differences for the prefixes 10.112.1.0/24 and 10.113.1.0/24:
  • both are known via type 3 LSA
  • the metrics from the two ABRs are different for 10.112.1.0/24, but the same for 10.113.1.0/24
  • the cost to the two ABRs should be different because of the square topology, which is confirmed by 10.112.1.0/24 showing two least cost paths and ECMP
Thus only 10.112.1.0/24 is known via two least cost paths that can be used for ECMP, the prefix 10.113.1.0/24 has but one least cost path, so no ECMP is possible.
Since 10.113.1.0/24 and 10.114.1.0/24 are compressed (flag c), i.e. omitted from the FIB, because a less specific prefix including both 10.113.10/24 and 10.114.1.0/24 has the exact same next hop(s), prefix 10.112.1.0/24 seems to be the outlier here.
Thanks,
Erik
Photo of Tomasz
Tomasz
  • 868 Points 500 badge 2x thumb
Hi Timothy,
Quick guess - is ECMP enabled? Looks like different link metrics and for some reason both paths to 10.112.1.0 have ultimate metrics of 12.
It would be easier to read and troubleshoot if you pointed some breader picture (where are the networks connected) and relevant config parts.
Regards,
Tomasz
(Edited)
Hi Tomasz,
EXOS shows all equal cost routes in the show iproute output, but if ECMP is not enabled, only one route is programmed into the FIB, as shown by the f flag.
Since two routes to 10.112.1.0/24 are shown as installed into the FIB, ECMP is enabled.
But it is a good observation that the routes towards 10.113.1.0/24 and 10.114.1.0/24 show a metric of 10, but the routes towards 10.112.1.0/24 show a metric of 12.
@Timothy: Please provide additional information about the network topology.
Thanks,
Erik
Timothy Corcoran
Tomasz,
ECMP is enabled
(vr VR-Campus) Mah-670-1.4 #  sh config | include iproute
enable iproute sharing vr VR-BldgServices
enable iproute sharing vr VR-Campus
enable iproute sharing vr VR-HSTDSVCS
enable iproute sharing vr VR-PCI
enable iproute sharing vr VR-vdi
enable iproute sharing vr VR-VoIP
configure iproute sharing max-gateways 16
In this particular case the VR in question is VR-Campus
The diagram shows the two aggregtion routers at the top.  These are the path back to the backbone. The two MAH routers at the bottom are the building routers for the Mahoney building.  The Mahoney routers are the gateway (VRRP) routers for all of the VLANs active in the Mahoney building.  The aggregation routers are the path out to all of the other buildings in area 0.0.3.2 and also to the backbone.
The aggregation routers are the ABRs for the area.  Several other buildings live in the same area.  Each building has a router pair connected back to the aggregation routers in the same fashion as Mahoney.  In our IP scheme the second octet is unique to a building. In the case of Mahoney 10.33.x.x are the VLANs in that building.
