Displaying correct port state for CISCO switches in Netsight
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Hello, everybody!
I have Netsight installation where many CISCOs are present. I can get many info from them using SNMP, instead of port state which is always ACCESS.
How can I get correct port state from CISCO switches in NetSight/OneView?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 3 years ago
  • 2
Photo of Tom Currier
Tom Currier, Employee
  • 760 Points 500 badge 2x thumb
Ilya;
What sort of Cisco devices are these?  You might want to create an online case in our support portal for further investigation at http://extremenetworks.com/support
Ilya Semenov
Hello, Tom!
My CISCO devices are: C2950, C2960, C3550, C3560, C3750, etc.
Have you ever seen that Netsight identifies CISCO port state correctly? In other words, is it possible technically?
Thank you!
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
Hi Ilya, what OID are you polling?  As far as I know, ifOperStatus=1.3.6.1.2.1.2.2.1.8 could be polled as it returns the following values:
ifOperStatus OBJECT-TYPE
SYNTAX Integer {
    up(1),
    down(2),
    testing(3),
    unknown(4),
    dormant(5),
    notPresent(6),
    lowerLayerDown(7) }
This particular OID is available in NetSight, however, if it turns out there is another Cisco specific OID, you might have to import the MIB it belongs to into NetSight.  As long as there's a MIB, anything is possible with NetSight
(Edited)
