Do I still need an external router to route between different VR , as teh extreme switch has one mac
  • Question
  • Updated 1 year ago
  • Answered
I have a customer who needs to route between virtual routers , normally I would do this , with some sort of extrenal routing box ( firewall or router )
I now have a customer who wants to do this on teh switch , I thought this was not possible as teh extreme switch has only one mac. I am about to upgrade to 16.1.3.6-patch1-10 , if that is any help.
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 1 year ago
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
(Edited)
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Rod, you can accomplish that using static routing.
Please see the article below:
https://gtacknowledge.extremenetworks.com/articles/How_To/Routing-configuration-between-VR-s
Rod Robertson
OK like the gtac knowledge , though to be honest dont like static routes.. if there are multiple networks within the vr's , then there will need to be a static route between each and every network both directions.. that's assuming that the networks within the vr are not contiguous .. ( within a /8 /16 address range )
So we come back to an external router , with basically a routing protocol.. OSPF area 0.0.0.0 and various other area's to match the Vr's
Photo of Mel78, CISSP, ECE
Mel78, CISSP, ECE
  • 1,044 Points 1k badge 2x thumb
Yes, current the inter VR is pretty limited. I have raised aGTAC  feature request to allow user-VRs to do static routing tracking (e.g. flow-redirect) which will be beneficial if you are dealing with different ISPs.
