Do we have a tool from extreme for network designing something similar to visio?
Arjumand_Qazi
New Contributor II
online designing tool from extreme networks
3 REPLIES 3
Patrick_Voss
Hello Arjumand,
We do not have an Extreme branded tool that will help with mapping out a network. Do you have an example of a tool that is made by another vendor that will do what you are asking for? The stencils are typically used within Visio to help our customers build a network topology.
Arjumand_Qazi
New Contributor II
hello,
it does not have any tool similar to visio, only the stencils for visio.
Ariyakudi_Srini
Hi Arjumand Qazi,
http://www.extremenetworks.com/support/documentation/
At the documentation page, if you will scroll down you will see "ExtremeSwitching – Hardware" with varying list of hardware types listed under it.
You can choose BlackDiamond or SummitX or SummitX-G2 from the list.
Thank You,
