Does ARP Inspection & DHCP Snooping affect POE Devices
  • Question
  • Updated 2 years ago
  • Answered
In Enterasys B5 switch, we have arp inspection and dhcp snooping protocols on. We got IP telephone with Poe. Sometimes these IP telephones can not register  to PBX server. These ports are not in trust mode. Can this affect IP telephones?
Thanks,
Best Regards
Photo of Erhan YILDIZ
Erhan YILDIZ
  • 180 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Jason Parker
Jason Parker, Employee
  • 2,908 Points 2k badge 2x thumb
First thing Happy New Year to all
The things to check:
Is the PBX
a. Static IP then if yes then it should be a trusted port
b. Do the phones show up with a binding (MAC and IP ) list
Are the phones going through WIFI
a. If the AP port is set to Arp Inspection and DHCP snooping then all it takes is for a statically assigned address traffic come across the wifi to the port on a switch and the port will be disabled for a moment
I suggest opening a ticket with the GTAC so we can assist you and resolve your issue. as there are more questions that I would ask, I will be glad to assist so mention to the Tech to please include Jason Parker as a copy to  in the case.-
Jason Parker
Erhan YILDIZ
Thanks for replying and sorry for late replying from me.
PBX,
a.PBX is in static IP and yes it is in trust port
b.the phones shows the mac.
No, wifi is not using for IP telephones.
The cable coming to telephone and from there its coming to PC.
Therefore 2 mac address for each port.
I will open a case.
Thanks,
Best Regards
