Does EOS support multi ospf process under the same VR
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
It just like cisco router ospf multi process - router ospf 1-65535
Photo of Wallance
Wallance
  • 260 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Ram
Ram, Employee
  • 1,450 Points 1k badge 2x thumb
One OSPF process can be used in one VRF only.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,792 Points 10k badge 2x thumb
Hi Wallance,
EOS on S-Series and similar switches does support multiple OSPF processes inside one VRF. According to the CLI Reference,
Multiple OSPF processes (process-id) are allowed per router. The S- K- and 7100-Series routers support 4 OSPF processes per VRF and 16 OSPF processes per router.
Please see the discussion thread S-Series: number of OSPF processes for 24 VRFs for additional info.
The limits stated in the CLI Reference are not enforced by EOS. The number of VRFs with dynamic routing protocols enabled is shown with the show limits command and probably enforced. The release notes show limits for the number of VRFs with dynamic routing protocols only.
Edit: To answer your question, EOS does support multiple OSPF processes inside one VRF similar to Cisco IOS.
Thanks,
Erik
(Edited)
Photo of Wallance
Wallance
Thanks Ram and Erik for your kindly response.
