Does promiscuous mode on VM adapter needed for VX9000
  • Question
  • Updated 3 weeks ago
HI there,
We are migrating from RFS6000 to VX9000, an existing WLAN with APs 6521,7522 and 6562.
For adoption all these APs , does promiscuous mode needed on VM adapter or not, and can you please advice for remote sites adoption over Layer 3 , the topology or ports that need to be configured.
Thanks In advance,
Theodore
Photo of theoadon
theoadon
  • 196 Points 100 badge 2x thumb
Posted 3 weeks ago
Photo of Andrew Blomley
Andrew Blomley, Employee
  • 962 Points 500 badge 2x thumb
if you configure a single access interface (management) on the VX 9000 promiscuous mode is not needed.
Photo of theoadon
theoadon
Thank you for the prompt response, but what if we have  2 VX9000 contollers in cluster mode?
still not needed you will be clustering you should cluster at layer 3.  and mint level 2 assuming you have a multi-site deployment
eg if you have adopted aps using mint level 2 the cluster should also be at level 2
We do not support mixed mint links on a controller
set the cluster
cluster name <cluster_name>
cluster mode active (default)
cluster member ip <ip_of_primary>
level <1|2>
cluster master-priority 250
cluster force-configured-state
cluster force-configured-statedelay5
to join a cluster login the secondary box
use the join cluster command
join-cluster <ip-addrees> user <admin> password <password> level 2
