Does the X440-G2-12p-10GE4 have fans?
  • 3
  • Question
  • Updated 2 years ago
  • Answered
I am looking for some silent PoE+ switches for a customer.  The data sheet for te X440 G2 series states the X440-G2-12t-10GE4 & X440-G2-12p-10GE4 show the 'BYSTANDER SOUND PRESSURE' as '0 dB(A) fan off' and 'DECLARED SOUND POWER (LWAD)' as '0 bels fan off'.
Does this mean they don't have fans or that the fans don't always
Photo of Andrew Butterworth
Andrew Butterworth
  • 120 Points 100 badge 2x thumb
Posted 2 years ago
  • 3
Photo of Aleixo Gomes
Aleixo Gomes, Employee
  • 334 Points 250 badge 2x thumb
Hi Andrew ,
could you confirm which firmware is being used on the switch , as i believe there is bug reported for one of the later  firmware with fans reported as failed for output #show fans
Andrew Butterworth
Hi, We don't have the hardware yet.  I am just trying to put together an equipment list. The customer has a requirement for PoE+ and quiet switches.  The data sheet for the X440 G2 series has a table titled 'FAN AND ACOUSTIC NOISE' and the X440-G2-12t-10GE4 & X440-G2-12p-10GE4 show the same details as stated in the 1st post.
Andy
Photo of Chad Smith
Chad Smith, Senior Escalation Support Engineer
  • 5,620 Points 5k badge 2x thumb
The 12t and 12p do have fans.  However, they operate with the fan off, unless under high PoE Load (i.e 100%) or very high temperatures.
(Edited)
Andrew Butterworth
Hi Chad.  Thanks for the reply.  In the documentation here - http://documentation.extremenetworks.com/summit/Summit_Family_HW_Install/Technical_Specifications_Ap...
it is slightly different to the data sheet in that it says both the X440-G2-12t-10GE4 & X440-G2-12p-10GE4 have a Bystander Sound Pressure of 14.7 fan off and a Declared Sound Power of 2.7 fan off.  However it also states this is "At 25°C and 50% PoE load where applicable".
Do the fans therefore come on when the temperature increases beyond 25°C and the PoE load is more then 50%?  Or are the fans off permanently?
Andy
