Does X670-G2 have support to a Virtual System?
  • Question
  • Updated 3 months ago
  • Answered
  • (Edited)
I can't find a complete information about it.
The datasheet says the have "Full ExtremeXOS® feature set supporting switching, routing, SDN,Data Center Bridging, MPLS, and Audio Video Bridging ", but I didn't found any information there about Virtual System.
Does have any function like this: https://gtacknowledge.extremenetworks.com/articles/Q_A/What-is-a-Virtual-Router/
Photo of Clayton Verlique
Clayton Verlique
  • 92 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Drew C.
Drew C., Community Manager
  • 40,240 Points 20k badge 2x thumb
Hi Clayton,
Welcome to The Hub!
If you're asking if you can create multiple virtual routers on the X670-G2, the answer is yes.
If you're talking about connecting a Virtual Machine Host, then that's typically standard networking and is also very much supported.
Clayton Verlique
@Drew C.
Thank you very much for your answer.
Do you know where I can find documentation about it?
Even if it is just the basic.
Photo of Ralf
Ralf
  • 494 Points 250 badge 2x thumb
Hi Clayton,
you can find the documentation in the EXOS User Guide: https://documentation.extremenetworks.com/exos_22.4/EXOS_21_1/Preface/c_introduction-ug.shtml
The link is for software version 22.4.
There is also a topic for virtual routers:
https://documentation.extremenetworks.com/exos_22.4/EXOS_21_1/Virtual_Routers/virtual-routers.shtml
For other software version visit the Support site, then Products Documentation -> Software -> Routing and Switching -> ExtremeXOS. There you can choose the software version via the drop down menu and you get an overview of all available guides and sheets.
Kind Regards, Ralf
Clayton Verlique
Thank you very much @Ralf. It will help me a lot.
