Downgrade Firmware Version XOS over switch x440
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
I need to make a greater Downgrade to a smaller version on a switch extreme x440 , what is the procedure?
Keep in mind that the version I want to get the just installed because of an error and should give isntalarla because I have not even restarting the switch and these teams are in production.
Photo of Jairo Rojas Herrera
Jairo Rojas Herrera
  • 1,452 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,714 Points 10k badge 2x thumb
Hello Jairo,
What version are you coming from and going to? Can you please elaborate on "smaller" version?
(Edited)
Jairo Rojas Herrera
I want to move from version summitX-16.1.3.6-patch1-2.xos to version summitX-15.6.4.2-patch 1-3
(Edited)
Patrick Voss, Alum
Can you give us the "show version images" and "show switch" output?
Jairo Rojas Herrera
* X440-24p.3 # sh version images
Card  Partition     Installation Date        Version     Name      Branch
Switch primary   Fri Nov 7 18:35:13 UTC 2014 15.5.3.4 summitX450-15.5.3.4.xos v1553b4
Switch secondary Tue Apr 19 16:38:34 UTC 2016 16.1.3.6 summitX-16.1.3.6-patch1-2.xos 16.1.3.6-patch1-2
Switch secondary Tue Apr 19 16:39:44 UTC 2016 16.1.3.6 summitX-16.1.3.6-patch1-2-ssh.xmod 16.1.3.6-patch1-2
Jairo Rojas Herrera
(Edited)
Patrick Voss, Alum
Hello Jairo,
It looks like it installed just fine.If you are trying to install a different image then you just need to go through the same process you went through to get 16.1.3.6 on the switch.
Jairo Rojas Herrera
need is the command to uninstall the last mount version
(Edited)
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Jairo, please check the Article below to avoid a login issue when downgrading the firmware from 16.x to 15.x:
Cannot log into EXOS switch after downgrading from EXOS 16 to an earlier release
Jairo Rojas Herrera
in this article does not explain how to lose version
(Edited)
Jairo Rojas Herrera
how i can downgrade to 16.x to 15.x
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Jairo, you can use the procedure described in the article below:
How to obtain a copy of the EXOS software and upgrade EXOS switches
You can follow the same procedure described under "Software upgrade procedure"
Just make sure to backup the configuration in ASCII and XML formats. It's recommended
Please check the article below about how to backup the switch configuration:
How to upload Backup Configuration to TFTP server on an EXOS switch
Just follow the Method 1 step1 for ASCII and Method 2 steps 1 and 2 for XML
Photo of Derek Bird
Derek Bird, Employee
  • 576 Points 500 badge 2x thumb
Jairo:
In the "show version images" output you provided, you still have 15.5.3.4 in the primary partition.  Simply issue
 use image primary
and reboot the switch.  I presume this is the image you were running prior to the upgrade to 16.3.1.6.
There's no way to roll back to whatever image existed in the secondary partition prior to your upgrade, but since EXOS does not allow you to install to an active partition, it's likely the primary is what you were running before.  Once you're booted into the primary partition, you can download a new image into the secondary partition, using the article detailing software upgrade provided by Henrique above.
Jairo Rojas Herrera
Photo of Derek Bird
Jairo:
The screenshot you provide is absolutely correct and expected behavior.
That partition has been written with the 16.1.3.6 image; it cannot be uninstalled, only installed over.
If you wish to return to the 15.x image present on the primary partition,
use image primary
reboot
And then you may install a 15.x image to the secondary partition, if you wish.
You can use the uninstall image command to uninstall the ssh xmod, but not the base code in the partition.
Jairo Rojas Herrera
