Download Extreme MIBS?
  • Question
  • Updated 2 years ago
  • Answered
I'm looking for mibs for all Extreme products (EOS, EXOS, Wing, IdentiFi, ...). I found the
following link:
http://www.extremenetworks.com/support/policies/mibs/
The are MIBS for EOS. The link for EXOS points to old esupport.
Where can I find MIBS for EXOS, Wing, IdentiFi.....?
Photo of Patrick Koppen
Patrick Koppen
  • 770 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,690 Points 20k badge 2x thumb
Hi Patrick,
EXOS MIBs are on the new support portal now:  https://extremeportal.force.com/
We'll need to get that page updated... thanks for pointing it out.
MIBs for the wireless products are on Extranet for now:  https://extranet.extremenetworks.com/downloads/Pages/default.aspx
-Drew
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
Correct. The mibs for the Extreme Wireless solution (formerly known as IdentiFi) are located at /mibs/third_party/siemens/ as you have mentioned
Patrick Koppen
ok, the IdentiFi MIBS are in the EOS tar file...
But if you look at the gtac article the link points to the download page in
extranet. There are MIBS for versions <=9.x. But the new mibs are missing.
thanks!!!
I updated the article Where can I download MIBs for the IdentiFi Wireless Solution? with the information about the location of the Extreme Wireless mibs.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,164 Points 50k badge 2x thumb
2nd sentence in the answer section of the article...
"Also per Product Management all MIBS for 9.21 or 10.x code should be included in the EOS Mib download -
http://www.extremenetworks.com/support/policies/mibs"
Photo of Christoph S.
Christoph S., Employee
  • 3,684 Points 3k badge 2x thumb
Hi Patrick,
WiNG MIBS are bundled up within the Firmware download package. Please follow this link for instructions on logging into our support portal:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-get-access-to-Extranet-for-for-firm...
Once in, go to Wireless > ExtremeWireless WiNG > Select the category > Download the firmware > In the Software folder you will find the MIBS file
Chris
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,488 Points 2k badge 2x thumb
what exact device with exos do you have?
Patrick Koppen
x430, x440, x670, x460, x770, .... but I'm not interessted in MIBS for a device. I need the MIBS for EXOS for Version 16.2 and 22.2.1.5.
I found it in the new Beta-Portal.
Thanks...
Patrick Koppen
