Draeger medical device
  • Question
  • Updated 1 year ago
  • Answered
Hi
we work in an Italian hospital. We need to connect some medical device, Draeger Infinity M300 telemetry transmitters, to our wireless Infrastructure.
What is the correct configuration that I need to consider ?
We have a V2110 Wireless Controller and many 3705i AP model.
Do you have any guide?
Thanks
Fabrizio Stoppani
Photo of Azienda Sant'Andrea
Azienda Sant'Andrea
  • 142 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Nico Willamowski
Nico Willamowski
  • 876 Points 500 badge 2x thumb
At first, you had to enable "Multicast Support" on ESA0. It ́s only possible to enable it on ESA0. Mulicast Assembly at the AP must be enabled (AP Proberties->Advanced->IP Multcast Assembly). You must have the actual firmware, problem with MTU Size is fixed in v8.32.05.007. But in Version 9 the problem still exists, but now it ́s fixed in version 9.12.02.0006. You have the fix the channel at the M300 and also at the AP!
Azienda Sant'Andrea
Really if I read the Infinity M330 datasheet , it speak about a Non-Multicast VLAN. I think that multicast works for another kind of device, for example medical monitors.
Nico Willamowski
At first you write M300 and now M330! What do you mean? The M300 is a medical monitor.
Azienda Sant'Andrea
Photo of Muedsam, Jochen
Muedsam, Jochen, Alum
  • 130 Points 100 badge 2x thumb
Hi, I have a confirmed Implementation Guide for Draeger. Pls send me your mail address and I can forward it.
Jochen
(Edited)
Photo of Neal Clonts
Neal Clonts
  • 70 Points
Do you still have this guide?
Photo of Drew C.
Drew C., Community Manager
  • 37,308 Points 20k badge 2x thumb
Hi Neal,
I've tried to find this document internally but didn't have any luck. It's been quite a while since Jochen posted and it seems he's no longer with the company. I'll try some other avenues to see if it turns up.
Azienda Sant'Andrea
Hi Jochen
Thanks a lot
fstoppani@csy.it
Photo of CarlyBatts
CarlyBatts
  • 60 Points
Traditionally medical devices have been hard-wired which not only consume lots of space, but have limited approach too. Wireless technology is changing the medical device industry rapidly and turning out to be the most preferred method for healthcare delivery system. It helps doctors and nurses to give patient’s better care and work more efficiently in safe environment. Draeger Infinity® M300 is one of the best examples of wireless technology medical device, which is useful for continuous standalone monitoring of patient, even when they are moving out of the wireless network coverage area of hospital. As you want to know about the connecting process for this device in hospital, I think this http://www.reuters.com/article/2008/08/12/idUS155357+12-Aug-2008+BW20080812 would be of help for you.
