Duplicated MACs on different VLANs on Same switched infra!
  • Question
  • Updated 1 year ago
  • Answered
My network includes more than hundred of switches in multiple-ring design ..
when issuing: show iparp
I am finding rejected IP .. I believe it doesn't has anything to do with the duplication ...
But I wanna be sure that I have no duplicated MACs on my network so...
- Does duplicated MACs on different VLANs on Same switched infra cause problems?
- How to find duplicated MACs on different VLANs on Same switched infra?
Thanks
Yusuf
Photo of Yusuf Kabbara
Yusuf Kabbara
  • 524 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Hi Yusuf,
I think it will give you ARP poison like problem since FDB maps each MAC to a port. Actually, I haven't tried that case. You should test it on separate switch to make sure.
Best regards,
Photo of simon bingham
simon bingham
  • 1,228 Points 1k badge 2x thumb
Just one point, to have same mac on many vlans can be perfectly OK, the decision about "what mac to the need to send this IP packet to " is a per vlan  question, not a network one. For example some vendors ( I know checkpoint do this ) you will see the same mac for every vlan for the same physical interface, for the checkpoint gateway. Of course if someone had connected one vlan to another like users sometimes do with edge points that's not so good.
Photo of French, Luke
French, Luke, Employee
  • 742 Points 500 badge 2x thumb
The same MAC can be on multiple VLANs because a MAC is not routed off the VLAN, rather, the router builds a new packet with its MAC before transmitting another VLAN. Some routers    have the same MAC on multiple interfaces. Net sight’s compass could be used to find  duplicate MAC's.
Mrxlazuardin
Interesting, I wonder how FDB table will be shown on that case.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
The FDB is populated per VLAN, so you will see multiple entries for the MAC in each VLAN that it exists in.
