Dynamic VLANS and STP
  • Question
  • Updated 2 months ago
  • Answered
Hello
¿How can I manage dynamic vlans with STPD? We have X450-G2
Photo of Pionio
Pionio
  • 252 Points 250 badge 2x thumb
Posted 3 months ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,034 Points 5k badge 2x thumb
How are you doing dynamic vlan's.  Netlogin, policy, script?
Photo of Pionio
Pionio
Hello Stephen
I'm using netlogin with mac authentication and radius.
Pionio,
In EXOS 22.2 and newer the STP auto bind feature now supports dynamic vlan assignment when using netlogin VSA's for vlan assignment.  It does not support dynamically created VLANs created by MVRP.
Configure Netlogin:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-802-1x-based-Netlogin-wit...
Configure STP:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-MSTP-in-EXOS
Photo of Pionio
Pionio
Hello Stephen
Step 7 from procedure (Configure STP):  Assign the VLAN to the MSTI.
The only VLAN created manually is the one for Netlogin. The others are dynamic VLANs. I suppose Netlogin VLAN is used in the STP configuration. Is this correct?
Thanks in advance
How are the VLANs being created?  We support stp with dynamic vlan assignment, not dynamic vlan creation.
Photo of Pionio
Pionio
Hello Stephen
This is our confguration:
- Netlogin VLAN: create vlan nt_login
-Config for allowing switch to connect network:
  * create vlan net tag 20
  * configure net ipaddress xxx.xxx.xxx.xxx 255.255.255.0
  * configure vlan net add ports 45 untagged (This is uplink port to core)
- Dynamic VLAN config for netlogin VSA
  * configure netlogin dynamic-vlan uplink-ports 45
  * configure netlogin dynamic-vlan enable
Thanks in advance
Photo of Brian Anderson
Brian Anderson
  • 312 Points 250 badge 2x thumb
The way I usually build spanning tree is have one vlan on the edge ports tagged and set it up for spanning tree, that way it doesn't matter which vlan is assigned to the ports dynamically, the spanning tree config stays static.
Photo of Pionio
Pionio
Finally we have configured MSTP with S0 domain and all VLANs and ports have been included.
configure stpd s0 mode mstp cist
enable s0 auto-bind vlan 1-4094
configure s0 ports auto-edge on 1-X
A loop was created manually and was managed by the switch
