E4G - E1 port specification
Alexandr_P
Valued Contributor
Hello!
Can somebody help with compliance with the requirements?
Is E4G ports E1 support next:
1 - 120 Ohm resistance
2 - ITU-T Rec G.703, G.704, G.706, G.732, G.823
3 - Speed - 2048 Mbps
4 - Coding HDB3, AMI
5 - Support E1 framed/unframed, with or without CRC-4
6 - Signaling CAS, CCS (transparent)
Thank you!
3 REPLIES 3
Chad_Smith1
Alexandr,
Number 5 is supported. We support framed or unframed E1. For framed E1 we support basic and multi frame both with CRC-4.
For number 6 our signaling option for a framed E1 is bit-oriented (CAS). I believe CCS would be transparent to the switch so we would pass the data but not act on it.
Thank you!
Alexandr_P
Valued Contributor
As I see - 1-4 is supporting, but have doubt about 5 and 6.
Thank you!
