EAPS
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hello,I have a set EAPS ring between three points interconnected with radios. However the customer must include an optical fiber, as another option of redundancy / balancing. What would be the best way to configure this scenario?
Photo of Felipe
Felipe
  • 252 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Felipe
Can you provide an diagram?  Usually depending on how that other link is connected we would do another EAPS ring and then use common links in the middle?
Thanks
P
Photo of Felipe
Felipe
Hello Paul,
Thanks for the feedback.
Follow the diagram, noting that is already configured one EAPS domain of the links via Radio, and the client is proposing the installation of optical fiber, that's the dotted line.
Photo of Colatuno, Joe
Colatuno, Joe, Escalation Support Engineer
  • 1,096 Points 1k badge 2x thumb
I agree with Paul here.  Creating two eaps domains and configuring the fiber link as the EAPS shared port should work in this scenario.
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
Software redundant port ? I would look at that option or LACP if the speed is the same ( at least what the extreme thinks the speed is )
Photo of Felipe
Felipe
The following diagram, noting that already is set one domain of EAPS.
Photo of Paul Russo
Paul Russo, Alum
Hello Felipe
In this case the best approach would be to have two domains, one top triangle domain and one bottom parallelogram domain.  This adds complexity as you then would need to do common links/shared ports on all of the triangle links.
Does that help?
P
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
If the diagram is correct and the switches are X440, you can't configure Shared Port because that feature requires Core Licenses, which are unavailable for X440...
Photo of Paul Russo
Paul Russo, Alum
good catch Daniel
Photo of Felipe
Felipe
Paul and Daniel,I thank immensely for their help.
Thus, in my current scenario would not be possible I keep three hits. That's it?
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Felipe,
In a scenario like this where you would like to have a port as a standby for redundancy, software redundant port configuration would have been the best option. However since we are running EAPS in the setup, we cannot enable SRP due to the following limitation.
"You cannot have any Layer 2 protocols configured on any of the VLANs that are present on the ports. (You will see an error message if you attempt to configure software redundant ports on ports
with VLANs running Layer 2 protocols.)".
Also we have a limitation with Edge license for the creation of the EAPS shared-port.
As per your statement in the description, you would like this setup for balancing. In that case, creating a LAG could be a consideration as Andreas pointed out. Can you confirm the port speeds of the optical fiber and radio connections? If they are different, sharing is out of the plate too!
As a last resort, we could implement an UPM script to enable the optical connection in case the radio connection fails and then disable the connection again when the radio connection restores. Script needs to be tested in lab first before implementing.
Just let us know ur thoughts.
Felipe,
There's another possibility...
ERPS (G.8032) supports rings and subrings with an Advanced Edge license, which is available for X440.
Let's call the lower left X440 in your diagram Switch1, the lower right X440 Switch2 and the upper X440 Switch3. You can configure a main ring between Switch1 and Switch2 using the fiber link and the radio link. One of those links would be blocked by ERPS (I would choose the radio link). You can also configure a subring between Switch1, Switch2 and Switch3. One of the links connecting Switch3 to Switch1 and Switch2 would be blocked by ERPS.
Let's say that:
  • Port 1 of Switch1 connects to port 1 of Switch2
  • Port 2 of Switch1 connects to port 2 of Switch2
  • Port 3 of Switch1 connects to port 1 of Switch3
  • Port 3 of Switch2 connects to port 2 of Switch3
The configuration for each switch would be:
# SWITCH 1
# VLAN configuration
config vlan default del port all
create vlan main_cv
config vlan main_cv tag 10
config vlan main_cv add port 1-2 tagged
create vlan sub_cv
config vlan sub_cv tag 20
config vlan sub_cv add port 1-3 tagged
create vlan pv1
config vlan pv1 tag 1000
config vlan pv1 add port 1-3 tagged
config vlan pv1 ipa 10.0.0.1/24
# Main-Ring configuration
create erps main_ring
configure erps main_ring ring-port east 1
configure erps main_ring ring-port west 2
configure erps main_ring protection-port 2
configure erps main_ring add control main_cv
configure erps main_ring add protected vlan pv1
configure erps main_ring add protected vlan sub_cv
configure erps main_ring timer wait-to-restore 600
enable erps main_ring
# Sub-Ring configuration
create erps sub_ring
configure erps sub_ring ring-port east 3
configure erps sub_ring add control sub_cv
configure erps sub_ring add protected vlan pv1
configure erps sub_ring timer wait-to-restore 600
configure erps main_ring add sub-ring sub_ring
enable erps sub_ring
enable erps
# SWITCH 2
create vlan main_cv
create vlan sub_cv
create vlan pv1
config vlan pv1 add port 4
config vlan pv1 ipa 10.0.0.2/24
configure erps main_ring ring-port east 2
configure erps main_ring ring-port west 1
configure erps main_ring neighbor-port 2
configure erps sub_ring neighbor-port 3
enable erps
# SWITCH 3
create vlan sub_cv
config vlan sub_cv add port 1,2 tagged
create vlan pv1
config vlan pv1 add port 1,2 tagged
config vlan pv1 ipa 10.0.0.3/24
configure erps sub_ring ring-port east 2
configure erps sub_ring ring-port west 1
configure erps sub_ring protection-port 2
enable erps
I set up a virtual lab using three EXOS-VM and it worked ok. Anyway, I would recommend that you do some tests and check that things work as expected before buying any additional licenses.
You can also configure CFM to improve convergence time.
Photo of Felipe
Felipe
Gentlemen,
Once again I thank the provisions time to assist me.
I will analyze all the possibilities presented by you guys.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
Daniel I captured your great ERPS example, and alternative configuration for EAPS with the X440.
Summit x440 EAPS shared port alternative configuration:
https://gtacknowledge.extremenetworks.com/articles/Solution/Summit-x440-EAPS-shared-port-alternative...
How to configure a ERPS ring with a sub ring attached:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-a-ERPS-ring-with-a-sub-ri...
Thanks!
