EAPS Shared port issue in Extreme-X460
Boopaa
We are keep on getting this below error in Summit X460 switch :
06/28/2017 15:58:05.48 EAPS Shared-port 29 - Neighbor reachable.
06/28/2017 15:58:05.09 EAPS Shared-port 29 - Neighbor reachable.
06/28/2017 15:58:04.47 EAPS Shared-port 29 - Neighbors Modes must be different. Common links must have unique Link-IDs. Please check the configuration.
We are using Summit X460-24t and which is running on ExtremeXOS version 15.3.1.4 v1531b4-patch1-14.
We have tried searching in GTAC knowledge but no luck and please suggest me the solution for this above error message.!!
Thanks in Advance.!!!
Regards,
Boopathy Chandrasekar
1 REPLY 1
Kawawa
You might have configured the same shared-port modes on both ends of the link. One has to be controller and the opposite end partner ,While the link ID must be identical on the link peers
http://documentation.extremenetworks.com/exos_commands_22.2/exos_21_1/exos_commands_all/r_configure-...
