eaps issues
  • Question
  • Updated 5 years ago
  • Answered
Can anyone explain me what is the role of protected vlan in EAPS ring and how it cause a loop when EAPS and STPD both configured in a protected vlan.Any response will be highly appreciated....
Regards,
Ajay Raj
Photo of ComraDe
ComraDe
  • 510 Points 500 badge 2x thumb
Posted 5 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
Hello Ajay
A protected VLAN is the VLAN that EAPS stops from making a loop. It is the VLAN you want to have redundant. The control VLAN is the VLAN that runs the EAPS protocol.
Running STP on an EAPS is a tricky design as you need to make sure that neither blocking protocol blocks the other. If this is on one EAPS domain ther is no reason to have both. If the design uses EAPS in a core ring and STP out to the edge then we would need to look at the design.
Why do you need STP and EAPS together? Was the loop only on one VLAN ?
P
