EAPS or ERPS? Differences?
  • Question
  • Updated 4 years ago
  • Answered
Hi Extreme Community
We made some great experience with EAPS in the past.
Actually i am building up a new Extreme-Ring. In the last Extreme-Course i did, i heard about ERPS.
What are the benefits of using ERPS instead of EAPS in a Extreme-Ring? Is it only the compatibility and standardization of ERPS? Or should i buld a new Ring generally with ERPS instead of EAPS?
I looked at the EXOS_Concepts_Guide but i didn't find any comparison between EAPS and ERPS.
Will be glad if anybode have a clue.
Thanks in advance and kind regards
Photo of Fed Ex
Fed Ex
  • 190 Points 100 badge 2x thumb
  • interessted
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Good morning Fed
There are a few differences that may make ERPS a better solution. First as you mentioned is compatibility with other vendors. Second is that ERPS allows for more design options. For example you can have a common link with multiple switches in the middle versus a direct point to point connection. third it allows for the user to set the ring in a broken state for maintenance and then recover the ring manually.
I will see if there are any other differences and will post a little later.
