eBGP VPN Extreme EXOS and Juniper
  • Problem
  • Updated 2 weeks ago
Hello guys,
Recently I post a question about vxlan configuration on Extreme Switches. Well, I've walked a little bit since that, but now i have maybe a problem:
I figured out that, once you enable EVPN encapsulation on Juniper BGP sessions, AFI/SAFI 25/70 are used to establish the sessions.
In EXOS, AF 1 SAFI 241 are used.  The problem is: This is a proprietary afi/safi  [ " The BGP implementation for ExtremeXOS supports carrying VXLAN VNI and LTEP combinations as MBGP routes using a proprietary af/saf combination.  " ] according to my research.
So, this is what we have:
Oct  8 12:08:52.288289 BGP RECV MP capability AFI=1, SAFI=241
Oct  8 12:08:52.288290 BGP RECV Refresh capability, code=2
Oct  8 12:08:52.288291 BGP RECV Refresh capability, code=128
Oct  8 12:08:52.288292 BGP RECV Unrecognized capability 70
Oct  8 12:08:52.288306 BGP RECV Param data (18 bytes): 01 04 00 01 00 f1 02 00 80 00 46 00 41 04 00 00
Oct  8 12:08:52.288344 bgp_parse_open_options: peer 3.3.3.3 (Internal AS 65000): unsupported AF 1 SAFI 241
It appears that EXOS will not talk to Juniper switches in a EVPN with VXLAN environment.
Some body had this problem and figure out any solution ? :-(
Thanks for any help.
Epafras Schaden
Photo of Epafras Schaden
Epafras Schaden
  • 130 Points 100 badge 2x thumb
  • frustrated
Posted 2 weeks ago
Be the first to post a reply!
