ELRP Acrosss stacks
  • Question
  • Updated 3 years ago
  • Answered
Create Date: Feb 18 2013 12:13PM
hi does elrp work across stacks? we do have some rooms which have ports going to different switch cupboards due to physical space in the original switch cupboard
(from conrad_jones)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Feb 20 2013 6:54PM
It doesn't. I'd recommend running it on all edge ports and configuring a disable-port exclude for the stacks' interconnect ports. This will provide a form of loop protection across the stacks, as the loop will eventually be detected at the edge port and blocked.
(from Ansley_Barnes)
Photo of Karina Del Moral
Karina Del Moral
  • 804 Points 500 badge 2x thumb
how do you exclude the stack ports?
