ELRP Bridging Loops
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Nov 28 2013 9:50AM
I'm trying to setup ELRP for the first time, I kind of have it working on a switch that has a tagged uplink port and then 12 ports untagged to vlan1 and 12 ports untagged to vlan2.
my query is how can I prevent a loop that bridges vlan1 and vlan2?
setup:
configure elrp-client periodic vlan1 ports 1-12 interval 5 log-and-trap disable duration 60
configure elrp-client periodic vlan2 ports 13-48 interval 5 log-and-trap disable duration 60
Thanks, Andrew
(from aengland)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Nov 28 2013 12:32PM
I also seem to have an issue where the uplink port which is tagged to both vlan1 & 2 goes offline if a loop appears on vlan1, even though ELRP has disabled the looped port, it's not until the looped disabled ports clears and re-enables that uplink comes back online. Loops in vlan2 have no affect on the uplink?
(from aengland)
Create Date: Dec 1 2013 9:47PM
have you tried configuring your uplink port to be excluded from being disabled?
configure elrp-client disable-ports exclude {port-list}
hth
christian
(from Christian_Kivalo)
Create Date: Dec 3 2013 4:04PM
This turned out to be a problem with another switch's ELRP it was unlinking too. Thanks for reply.
(from aengland)
