EMC maps - no style / draw wall option
  • Problem
  • Updated 2 years ago
  • Solved
I'm running EMC 7.0.6.27 with a valid NMS-ADV-U license but don't see the option to draw walls.
The map proberties are set to floorplan, custom and I've selected edit but there is no style option as mentioned in the online help.
I haven't played with the draw wall map function for a while so might be that I'm doing something wrong.
-Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
Posted 2 years ago
Photo of Rich Upshaw
Rich Upshaw
  • 1,140 Points 1k badge 2x thumb
Use the drop down where it says select items.  The drawing tools are there.
There is no draw wall option in select items - as per the online help the style option should be right beside the select item pull down but there is nothing in my case.....
Rich Upshaw
Try a different browser.  Could be that.
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,774 Points 5k badge 2x thumb
Ron, what do you see when you click "Select Items"?  You should be able to click "line" or "square" or something. In fact, you should be doing that before Style or Wall shows up, which is odd.
Is this perhaps a browser bug? Could you try using IE/Chrome/Firefox/etc?
LOL, you are right, if I select one from the select items list I've the style option available.
Thanks a lot....
