EMC traffic to switches on SSL and HTTP
treese
Contributor
EMC is sending 443 and 80 to our edge switches. We don't have this allowed but I want to know what part of EMC is generating this and if I can disable it.
Thank you
2 REPLIES 2
Zdeněk_Pala
it is strange. how often it does happen? what are those switches?
If you use ZTP+ or scripting then there is/can be JSON-RPC calls.
Regards Zdeněk Pala
treese
Contributor
Just to clarify I have switches on the other side of the FW and since SSL and HTTP isn't in the rule we are blocking this traffic. I'm trying to figure out what EMC uses this for. The App seems to be working fine. Its managing the switch.
