Enable ssh2 or telnet on XOS without using the console port
  • Question
  • Updated 10 hours ago
  • Answered
Hello, at all!
I have made a mistake by disabling ssh2 and telnet on an X460G2 (fw 22.4.1.4). And now i can't manage the switch per remote. Is there a possibility by enabling ssh2 or telnet on this switch without driving to the system and using the console port?
Thanks for your interesting!
Photo of Carsten Volmer
Carsten Volmer
  • 274 Points 250 badge 2x thumb
Posted 2 weeks ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,314 Points 10k badge 2x thumb
Hello Carsen,
I apologize. I think your only option is to console in to make the configuration change.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 43,034 Points 20k badge 2x thumb
is web still enabled ?
did you save the config > if not could someone onsite just unplug/plug the power cable
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,442 Points 3k badge 2x thumb
Is the web interface still working? You could try that.
If you have a python environment on your server, you could try using the jsonrpc_client.py
https://github.com/extremenetworks/EXOS_Apps/tree/master/JSONRPC
Photo of Necheporenko, Nikolay
Necheporenko, Nikolay, Employee
  • 1,300 Points 1k badge 2x thumb
If snmp rw community is configured you may try to do reboot remotely - https://gtacknowledge.extremenetworks.com/articles/How_To/Setting-the-Next-Reboot-time-via-SNMP-with...
  • 43,032 Points 20k badge 2x thumb
Is it possible to just set ssh to enable via SNMP or is there no such MIB object ?
Carsten Volmer
The web interface isn't working  either ..
Photo of Rod Robertson
Rod Robertson
  • 2,282 Points 2k badge 2x thumb
How about using the password recovery solution. .XSF file.
Don't know if I  am allowed to copy and paste it here , Im sure there will be a GTAC document , just replace create account admin test test with Enable Telnet.
Basically autoexec.xsf should load before the configuration.
