Enable SummitStack-V on single switch?
  • Question
  • Updated 3 weeks ago
  • Answered
In the past, our best practice was to enable stacking on everything (including single switches), allowing for future additions to the switch without having to suffer an outage and reconfiguration. It seems that when using 10Gb stacking on a 460-G2, unless you boot with a connected "secondary" switch, the enable stacking command has no impact and the switch refuses to enter stacking mode by itself. Can anyone confirm this behavior? Any suggestions to accommodate the expansion without reboot scenario?
Thanks,
Eric
Photo of Eric Burke
Eric Burke
  • 2,426 Points 2k badge 2x thumb
Posted 3 weeks ago
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
This could be code related.
We have several X460-G2s deployed as single switch stacks using the alternate front ports.
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,878 Points 2k badge 2x thumb
What EXOS version are you running?
I did a quick test in my lab and don't see this, i.e. I am able to enable stacking on a single node:
* Slot-1 Stack.1 # sh slot
Slots    Type                 Configured           State       Ports
Slot-1   X460G2-48x-10G4                           Operational   54
Slot-2                                             Empty          0
Slot-3                                             Empty          0
Slot-4                                             Empty          0
Slot-5                                             Empty          0
Slot-6                                             Empty          0
Slot-7                                             Empty          0
Slot-8                                             Empty          0
* Slot-1 Stack.2 # sh stacking-support
Stack    Available Ports
Port    Native  Alternate  Configured  Current
1       Yes     51 *       Alternate   Alternate
2       Yes     52 *       Alternate   Alternate
stacking-support:          Enabled     Enabled
Flags: * - Current stack port selection
* Slot-1 Stack.3 # sh stacking
Stack Topology is a Daisy-Chain
Active Topology is a Daisy-Chain
Node MAC Address    Slot  Stack State  Role     Flags
*00:04:96:9b:c2:0f  1     Active       Master   CA-
* - Indicates this node
Flags:  (C) Candidate for this active topology, (A) Active Node
        (O) node may be in Other active topology
* Slot-1 Stack.4 #
(Edited)
Photo of Eric Burke
Eric Burke
Running the recommended 21.1.5.2 build. If I show stacking-support, it says enabled but the port references from a configuration standpoint don't seem to use the switch:port commands (just port). Again, nothing is connected to the back stacking ports (27/28). In SummitStack if you enabled stacking on a single switch, the port commands would reference switch:port just like a multi-switch stack.
Even if stacking is enabled you still need to configure staging to trigger the reboot and create the stack. It sounds like you are short a command or two.
Photo of Mel78, CISSP, ECE
Mel78, CISSP, ECE
  • 1,044 Points 1k badge 2x thumb
Have you run the "enable stacking" after "you configure stacking .... "  ?
Also just for everyone information, SummitStack-V do support SFP+ BiDi as show below.
This can saves up on your precious FO core asset.
Photo of Eric Burke
Eric Burke
Boy do I feel dumb... :-)  So used to stacking on SummitStack that I missed a step on the 10GB stacking (easy-setup). While I configured and enabled stacking - it seems that without this command at the end I was not really done. Thanks for the quick responses!
