enable ssh without reboot
  • Question
  • Updated 5 years ago
Create Date: Aug 26 2012 8:18PM
Hi All,
I've just upgraded our new switches to 15.1.3 and did not install the ssh mod before reboot.
It's now installed, is there a way to refresh the cli so we can start sshd or is it a full reboot so it sees the xmod installed?
(from luke_iggleden)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Aug 27 2012 2:57AM
try:
start process "exsshd"
Jarek
(from Jaroslaw_Kasjaniuk)
Create Date: Aug 27 2012 4:07PM
Well, no idea about the effect of restarting the process recommended by above user.
If you pay attention to the cli once you install the SSH image - it will tell you that you need to restart "thttpd" and "snmpMaster"
(from Eugen_NAIMAN)
Create Date: Aug 27 2012 5:30PM
Slot-1 STACK.1 # run update
Slot-1 STACK.2 # sh proc exss
Card   Process Name     Version  Restart    State             Start Time
Slot-1 exsshd           4.1.2.0     0    Ready        Tue Aug 28 10:27:02 2012
Slot-2 exsshd           4.1.2.0     0    Ready        Tue Aug 28 10:27:00 2012
Run update loaded the module, then enable ssh2 as per usual.
Thanks Guys.
