Enforce fail on NAC
  • Question
  • Updated 3 years ago
  • Answered
Hi :-),
when I try to enforce the NAC appliances, I get a fail message (see pic below).
In the NAC Manager I can see the reason under "Status".
How can I solve this problem?
- The Netsight Server VM has a disabled firewall.
- SNMP settings are correct.
- I can see the appliances in Netsight Console and they are up. (Device Manager works too)
Thanks for any replies :-)
Photo of Tyrone Knight
Tyrone Knight
  • 260 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,488 Points 5k badge 2x thumb
Hi Tyrone. Did this ever work?
The NAC Icons are orange, this is typically a license issue.
You may want to review the following article
https://gtacknowledge.extremenetworks.com/articles/Solution/NAC-Orange-Arrow-in-NAC-manager-Unlicens...
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,024 Points 20k badge 2x thumb
A red/orange arrow means that there is a communication problem.
In short, without communication no enforcement.
SSH to the NAC appliance and run "nacstatus" - this might give some information on what is going wrong in the section "Communications Diagnostics",
If you see there a issue with WebServices you'd try...
https://gtacknowledge.extremenetworks.com/articles/Solution/New-NAC-Appliance-Green-in-NetSight-Cons...
What have you done tp run into this problem ?
-Ron
Tyrone Knight
Update: Problem solved.
There were wrong DNS server IP addresses in the appliance network settings over the NAC Manager.
Thanks again for your help! :-)
(Edited)
