Enforcing Netsight 6.3.184 Console trunk template on EXOS x440-g2 problem
  • Question
  • Updated 2 years ago
  • Answered
Hi
I have a problem to execute port template (trunk port template) which was made with Netsight Console 6.3.184 on x440-g2 port (with EXOS)
What can cause the problem? How to make it work ?
please help
Regards
Marek
Photo of Marek Konopinski
Marek Konopinski
  • 468 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Daniel B
Daniel B
  • 360 Points 250 badge 2x thumb
Hi Marek,
I think the VLAN configuration with NetSight work only with EOS not with EXOS till now.
Regards Daniel
Marek Konopinski
So your saying that i need to upgrade / move to Exreme Managment 7.0 (nac 7.0)  and it will work ritght?
(Edited)
Photo of Daniel B
Daniel B
No, in Extreme Management it is the same. You can configure native VLANs via OneView or NetSight Console. But on trunks I mean you have to do it by hand on the shell.
https://gtacknowledge.extremenetworks.com/articles/How_To/Netsight-XOS-Vlan-Management
https://community.extremenetworks.com/extreme/topics/vlan-configuration-via-netsight-or-oneview-basi...
Marek Konopinski
its kind of like that with extreme in this situation
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,660 Points 1k badge 2x thumb
Hello Marek,
vlan MIBs has been added in latest 22.1 release.
on the EXOS switch you need to enable the VLAN auto-move function.
configure vlan untagged-ports auto-move on
This feature is real new, and allow to change the untagged VLAN on an port in one call.
regards
BAstian
Marek Konopinski
i dont want to change untagged vlan in one call, i need to setup trunk port from trunk template from netsight console...
which Software you running on the x440-g2
regards
Bastian
Marek Konopinski
i have 21.1.1.X
