Enterasys 3605 blinking red and green
  • Question
  • Updated 3 years ago
  • Answered
I have Enterasys AP 3605. I approved it and it was working fine last week. This week, the controller says it's down. The AP is plugged in, but blinking red and green. Does anyone know what caused the AP to go down? I checked the log and it said poll timeout, but I have had other APs do that and come back up by releasing them from the backup controller. I tried rebooting it remotely, but that didn't do anything, and it's not active in the backup controller.
Photo of Laura
Laura
  • 982 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Laura,
Which LEDs are lit? If the access point is facing you with the logo towards you, read the LEDs from 1-4 left to right.
Photo of Doug Hyde
The port the ap was plugged into on your switch, was it configured for 802.1x authentication? You can authenticate the access point if all the configuration parameters are setup on the ap.
Photo of Laura
Laura
  • 1,550 Points 1k badge 2x thumb
I am no sure. Not really familiar with what 802.1x is.  My manger just changed out our old Cisco switches with new Brocades. All the APS were up and running before the swap. Now 3 APs are blinking red and green.
Photo of Doug Hyde
Have you tried moving the ap to a known good port where a working ap currently is?
(Edited)
Photo of Laura
Laura
no, but i checked the data drop, and is it good and handing out the correct address.
Photo of Doug Hyde
Check out the following GTAC Knowledge article to find out more on the diagnostic LED combos....  https://gtacknowledge.extremenetworks.com/articles/Q_A/What-do-the-AP3610-LED-colors-represent
This should help.
-Doug
Photo of Raffi
Raffi, Employee
  • 1,598 Points 1k badge 2x thumb
If you are remote and looking at the leds is difficult, you can ping it or ssh to it to see what it is doing. If you know or can find the ip of the ap, ping it to verify it is up. You can ping /t for abit just in case it is rebooting. If you can ping, then we could ssh to it and do some troubleshooting to see what is wrong, and possibly fix it.
