enterasys A4 Copy firmware From Switch to PC?
  • Question
  • Updated 2 years ago
  • Answered
Greetings to you
I'm tired from searching in Google about " how to save current firmware in switch to PC , The main goal from this is take a backup
I Know how to save config file to my pc it's easy by using this command
A4(su)->show config outfile configs/mysave.cfg
A4(su)->copy configs/mysave.cfg tftp://10.10.10.15/Ali_j_albasri.txt
File transfer operation completed successfully.
so the above command using to save config file to my PC using TFPT ,
we know in Cisco you can save IOS Image by using IOS name and TFTP
Like this command
copy flash/c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin tftp:server
so i want to do that in Enterasys switches
Photo of Ali .J
Ali .J
  • 150 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Jason Parker
Jason Parker, Employee
  • 3,018 Points 3k badge 2x thumb
Here are some basic command examples for you
>Make running configuration
to save config to switch
show config outfile configs/Dec16_09.cfg
->To copy config to TFTP server>
copy configs/Dec1609.cfg  tftp://10.26.196.5/Dec1609.cfg
copy configs/before-6-61-08-0013.cfg tftp://10.26.196.5/before-6-61-08-0013...
>To Delete configs
delete configs/before-6-61-08-0013.cfg
->To pull config from tftp to switch
 copy tftp://192.168.0.90/Dec1609.cfg configs/Dec1609.cfg
->Make running:
configure configs/Dec16_09.cfg <<
Jason
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
I don't think that it's possible to upload the software from the switch.
The solution to your problem would be to just download the software image that you are looking for from the Extreme webpage to your PC.
Sorry,
Firmware to switch cannot be done.
I thought you were trying to load the Config to PC.
My Mistake
Jason
Photo of Ali .J
Ali .J
Jason Parker thank you for your fast replay , but i need to save IOS from switch to my pc
as you know in Cisco routers and switches you can get IOS from switch to your pc by using TFTP
kindly take a look to this video , i want to get IOS From switch to my PC
https://www.youtube.com/watch?v=pEuDgGLS6Wo
Ronald Dvorak
Thank you for your fast replay ,, i know to download image form website , but i want to get that image from switch to my pc .
Photo of John Valentine
John Valentine, Sr. Solutions Engineer
  • 200 Points 100 badge 2x thumb
I do not have an A4 currently to verify, but have used the following on other Enterasys switches:
A4> dir   (to see firmware names in the Images directory)
A4> copy images/firmware_name  tftp://a.b.c.d/name
Photo of Ali .J
Ali .J
John Valentine
i did that command before but not success
Username:admin
Password:
Enterasys A4
Enterasys Networks, Inc.
50 Minuteman Rd.
Andover, MA 01810-1008 U.S.A.
Phone: +1 978 684 1000
E-mail: support@enterasys.com
WWW: http://www.enterasys.com
(c) Copyright Enterasys Networks, Inc. 2011
Chassis Serial Number:      12240066905L
Chassis Firmware Revision:  03.03.01.0011
A4(su)->
A4(su)->
A4(su)->dir
Images:
Filename:      a-series_03.03.01.0011 (Active) (Boot)
Version:       03.03.01.0011
Date:          Thu Mar 31 06:26:44 2011
CheckSum:      818707264b41c7c00764fe4a70d7a467
Compatibility: A2H124-24, A2H123-24, A2H124-24P, A2H124-48, A2H124-48P
               A2H124-24FX, A2H254-16, A4H124-24TX, A4H124-24FX, A4H254-8F8T
               A4H124-24, A4H124-24P, A4H124-48, A4H124-48P
Files:                           Size
configs:
mysave.cfg                       2149
logs:
current.log                      5393
A4(su)->
A4(su)->copy images/a-series_03.03.01.0011 tftp://10.10.10.15/fw
Error: Couldn't open source file!
A4(su)->
Same here on a G3
Filename:      g3-series_06.61.09.0003 (Active) (Boot)   <-----------------------
Version:       06.61.09.0003
Date:          Wed May 22 06:27:46 2013
CheckSum:      a745f2ba342627abcf036186d8c5b565
Compatibility: G3G124-24, G3G124-24P, G3G170-24
Files:                           Size
configs:
JasonsPoe                        92261
10-23-2012.cfg                   14577
G3Lab.cfg                        8293
G3GQuerierandVLAN3-4-308.cfg     8293
G3routngospf.cfg                 8293
MyG3Ghost                        2149
Portmirrorand-Ghost.cfg          6245
G3Routing.cfg                    10341
before-upgrade-6-61-08-0013.cfg  14577
G3G124-24P-198-200-2014.cfg      16645
logs:
current.log                      512017
secure:
secure/logs:
G3G124-24P-198-200(su)->copy Images/g3-series_06.61.09.0003 tftp://10.58.196.5/g3-series_06.61.09....
Looks like Jason tried my next suggestion with the capital "I" instead of "i".  Not sure then.  So it's either a restriction of the switch and/or firmware, or perhaps it cannot be done with the file that's the active/boot firmware image.  Not sure why that would be the case, but I've seen stranger things.  My previous success was with S-Series switch.
Photo of Ali .J
Ali .J
John ,
same even if you Type Images "Capital i
Is there a solution to this problem? Frankly Compared with Cisco offers you a quick solution to solve this problem
Is there a solution ?
I think the switch is designed that way so I don't see a problem.
The solution to your request is to download the software from the Extreme webpage.
This is not supported on the SecureStacks. You will need to call into the GTAC and open a C4(care Request) and management will review and comment if this request  can be done.
Photo of Ali .J
Ali .J
Thanks Jason
you said "call into the GTAC and open a C4(care Request)" , could you tell me where i can do that ?
  • 48,764 Points 20k badge 2x thumb
Here the link to the contact information of the GTAC..
http://www.extremenetworks.com/support/contact/
The GTAC will open a ticket with your CR (change request).
Then product managment will decide whether the new function will be implemented into a new firmware build.
Photo of Bilal Bozduman
Bilal Bozduman
  • 60 Points
how is problem
C3(su)->configure configs/Jan11_2006.cfg
Could not open configs/Jan11_2006.cfg for reading.
