Enterasys transceivers on extreme switches
  • Question
  • Updated 1 year ago
  • Answered
Hi ,
I want to use the below transceivers on the extreme summit switches. If yes on which which summit switches.
MGBIC-LC-09
MGBIC-LC-01
Thanks
Syed
Photo of Syed Arshad
Syed Arshad
  • 204 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Hernandez, Joshua
Hernandez, Joshua, Employee
  • 1,564 Points 1k badge 2x thumb
Syed Arshad,
It is possible that these Gigabit transceivers will work on EXOS switches; however, if possible put the optic in an EXOS switch and with a cable connected run the following command and provide the output.
debug hal show optic-info ddmi port <port#>
This output will provide some additional output.
Syed Arshad
I do not have them with me.
Did you try using them and they worked fine ?
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,436 Points 2k badge 2x thumb
You should try them yourself, in most cases 3rd party transceivers work well
Photo of Jason Parker
Jason Parker, Employee
  • 3,018 Points 3k badge 2x thumb
There was a display issue is earlier firmware that would report "not supported " on some transceivers but that has been addressed so it is always a good point to upgrade but if the traffic passes without any issues you should be good to go.
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,732 Points 2k badge 2x thumb
The release notes are the go to documentation for these questions.  If it is listed in a release as supported then it should be. If there are issues let us know.
