EPS-500 External Power Supply Unit (Model 10911) compatibility with the Summit X440 48t and 48P.
  • Question
  • Updated 3 years ago
  • Answered
Hi, Can anyone tell me if the EPS-500 External Power Supply Unit (Model 10911) is compatible with the Summit X440 48t and 48P. The pins look like they will connect but I just wanted to be sure.
Photo of Raghurajan, Sandeep
Raghurajan, Sandeep, Employee
  • 172 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,458 Points 50k badge 2x thumb
Hi, doesn't look like if you check the datasheet...
http://learn.extremenetworks.com/rs/extreme/images/Summit-X440x-DS.pdf
-Ron
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
I do not believe that the EPS-500 is compatible with the X440, there is firmware that it needs to work correctly and the 500 is an old unit with a fixed power supply.  The one compatible is the EPS-C2.
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,536 Points 3k badge 2x thumb
Hi Sandeep,
EPS-500 External Power Supply Unit (10911) can be used for below models.
• Summit X150-24p switch
• Summit X250e-24p switch
• Summit X350-24t switch
• Summit X350-48t switch
• Summit X450a-24t switch
• Summit X450a-24x switch
• Summit X450a-48t switch
• Summit X450e-24p switch
• Summit X450e-24t switch
• Summit X450e-48t switch
Thanks,
Suresh.B
Photo of Syed Arshad
Syed Arshad
  • 204 Points 100 badge 2x thumb
Yes it is compatiable
Regards
Syed Arshad
Photo of Drew C.
Drew C., Community Manager
  • 40,858 Points 20k badge 2x thumb
Have you used the EPS-500 successfully on one of your X440s?
Syed Arshad
Nope. My bad it doesn't i beleive. 440 support RPS-500p.
Apologies
