ERLP not working when using vlan default
JohanHendrikx
Contributor II
I have a X440-G2-24P-10GE4 switch and configured two vlan's. VLAN-A and VLAN-B
Firmware is 22.4.1.4
In VLAN-A there are the ports 1,2,3 and 4 and in VLAN-B ports 5,6,7 and 8.
To make sure that there a no connetions made between VLAN-A and VLAN-B on the switch I configured all ports tagged in vlan Default and configure ELRP:
configure elrp-client periodic Default ports 1-8 interval 1 log-and-trap disable-port permanent
Since firmware 22.2 STP is by default enabled on vlan Default.
When I connect port 1 and 2, both ports go up and ELRP doesn't work, till I disable stpd.
Is this normal behaviour ?
Johan Hendrik System Architect Audax
1 REPLY 1
Chad_Smith1
Johan,
With STP enabled on VLAN default one of those ports will be blocked, preventing ELRP from working. If I understand the situation correctly.
