ERPS and Defaul vlan
  • Question
  • Updated 4 years ago
  • (Edited)
Hi everybody.
Can I add Default vlan as protected vlan to ERPS ring?
configure erps ring0 add protected vlan "Default"
Error: Cannot configure VLAN "Default"
Error: Failed to add "Default" as protected VLAN
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 4 years ago
Photo of rbrt_weiler
rbrt_weiler
  • 834 Points 500 badge 2x thumb
Tried this on a test switch and get the same message. Adding another untagged VLAN works flawlessly. So I'd say that VLAN Default is off limits for ERPS.
(By the way, using VLAN Default (with tag 1) in a production environment is considered bad practice.)
Photo of eyeV
eyeV
Thank you for answer. But we use vlan 1 in our company, unfortunately ( And we should add it into ERPS ring.
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Contact the TAC and report this issue.
Sumit Tokle, Alum
We are tracking this issue with our internal team. Will update you shortly on this issue.
Photo of eyeV
eyeV
Great! Thank you.
