ERRDISABLE EXTREME NETWORKS STP LOOP PREVENT
Tavares_Belmont
New Contributor II
Hello all,
I would like to know if its possible create loop prevent with ports on the same switch (X450E 48P) For example:
Vlan default ports 1-16 tag 1
Vlan RH ports 17-32 tag 10
Vlan adm ports 33-48 tag 20
ipfowarding enable...
If simulate loop between 2 ports same vlan or another i would like block one or both ports participants, like a 'errdisable" cisco feature...how can i?
5 REPLIES 5
Tavares_Belmont
New Contributor II
You save my life!! Thanks Warrior!!!
Awesome! Thanks for sharing.
Tavares_Belmont
New Contributor II
Thanks,
But "Invalid URLThe requested URL "/articles/How_To/How-to-configure-ELRP-to-disable-ports/?q=elrp&l=en_US&fs=Search&pn=1", is invalid.
Reference #9.cd1d7ba.1432305079.158a4c28"
